Re: Manual valve bodies... Do they improve ET?
[Re: MikeyT]
#1690239
10/27/14 12:18 PM
10/27/14 12:18 PM
Posts: 12,159 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Hutch,
Believe it or not but my 60 foot time, my best was 2.2. Also, Cab I agree I am always worried about TF linkage, so I had my transmission guy help set it up correctly.
My concern is HP in general
A 9:1 440 with decent 915 heads, headers, 703 lunati cam, Holley dominator intake,and 750 carb , SHOULD be able to push a car into low 13's at Least..
2.2 60'?!?!?!
I'ld be working on the 60' BEFORE anything else.
Master, again and still
[Re: Thumperdart]
#1690241
10/27/14 01:01 PM
10/27/14 01:01 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Ok... Well let's look at it..
3990 lb race weight 3600 stall converter 3.55 gears 275/60/15 nitto drag radials ran at 20 psi
Launched at 2000, 2500 , and 3000 rpms and it felt like it hooked
Mike
1969 Dodge Dart Swinger
[Re: 80fbody]
#1690246
10/27/14 10:17 PM
10/27/14 10:17 PM
Posts: 240 Ft. Wayne, IN.
QTR MILR
Ft. Wayne, IN.
It does sound lazy out of the hole. What is the timing set at, initial and total? Also have you tried playing with the accelerator pump at all??
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
[Re: BSB67]
#1690248
10/27/14 11:20 PM
10/27/14 11:20 PM
MikeyT
Watertown, WI
Initial. 22 degrees and 38 total at 2500, And I agree at 4000 lb and 260 hp, that would be what I expect but this is a mildly built 440, it should have more then 260 hp in it? I am not talking something crazy but I think it should have more? My question is why... Possible jumped teeth on timing chain, something else? Mikey Ps maybe it is just time to throw my stroker 508 in it and be done with it
[Re: MikeyT]
#1690249
10/27/14 11:25 PM
10/27/14 11:25 PM
MikeyT
Watertown, WI
Also, agsin... Thank you so much for all the knowledge and expertise...I always feel very fortunate to have such wide variety of help!
Thanks agsin guys
