Re: My W9 Build
[Re: TRENDZ]
#1690119
10/25/14 02:52 PM
10/25/14 02:52 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Seems like a waste to run such a tiny cam and bore on a motor/ heads with a lot of potential.
sometimes "potential" is pretty hard on stuff....
Would be a sweet cam for a turbo motor
Now there's an idea! ![](/ubbthreads/images/graemlins/thumbs.gif)
Matt
Re: My W9 Build
[Re: Thumperdart]
#1690120
10/25/14 03:02 PM
10/25/14 03:02 PM
MattW
Ontario Canada
My first thaught.............hugh lift but baby duration........
Keep in mind that this venture was a last minute deal so to speak. The stuff that's in this engine is stuff that was already purchased. I was not built specifically for engine masters. It was more of let's see what all this can do. I had a couple of limiting factors one being a hydraulic roller and compression. I want to be able to drive this thing around town if I ever get my junk together. Matt
Not baggin and using what you`ve got it is what it is..............
All good ![](/ubbthreads/images/graemlins/thumbs.gif) Not a keyboard whiner. Truth is it will probably sit for awhile before anything happens. R3 is good but not worth my time for high compression big mechanical with the sloppy 59 degree lifter angle. I would love to have a 48 degree siamese block. But I've moving towards the new G3. Matt
Re: My W9 Build
[Re: B3422W5]
#1690121
10/25/14 04:13 PM
10/25/14 04:13 PM
Posts: 3,397 Pa
Hot 340
Pa
The little enginemaster's 318 I bought has a 6.200 Scat I beam Chevy rod in it.
With a 2.0 journal?
Re: My W9 Build
[Re: BPE]
#1690124
10/25/14 08:47 PM
10/25/14 08:47 PM
MattW
Ontario Canada
I'm pretty sure scat doesn't make a small journal I beam SBC rod in 6.200" length. But, I have been wrong before.
Rod
I've seen them but can't find tthem . lol It's an I beam and it's 6.20 and your crank is 2.00 rod sooooo ![](/ubbthreads/images/graemlins/shruggy.gif)
Re: My W9 Build
[Re: SpareParts]
#1690128
10/25/14 09:34 PM
10/25/14 09:34 PM
Posts: 1,051 The Great White North
RAMM
The offset is .770" and it needs every bit of it. Scat DOES offer the rod in a 2.00" journal, its right on their site in the Chevy section. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
Re: My W9 Build
[Re: RAMM]
#1690129
10/25/14 09:39 PM
10/25/14 09:39 PM
Posts: 3,397 Pa
Hot 340
Pa
Not 6.200 long. T&D makes a .775 for the rp head. Its what I'd use on a 59.
Re: My W9 Build
[Re: RAMM]
#1690134
10/26/14 11:11 AM
10/26/14 11:11 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
how much power is he leaving on the table running a small bore combo
We will never know. J.Rob
what would be your minimal bore size for the w9/8 head would you run thanks
Re: My W9 Build
[Re: RAMM]
#1690136
10/26/14 11:35 AM
10/26/14 11:35 AM
Posts: 458 Michigan
BPE
There is nothing listed on Scat's website for an I beam in 6.200" with a small journal. You might be thinking an H beam (that's listed). Thanks for the info on the T and D part number. ![](/ubbthreads/images/graemlins/thumbs.gif)
Rod
I will supply the part # on Monday along with a phone number and contact name @ Scat Enterprises. J.Rob
Thanks, I contacted them a while back checking on them and they said they didn't make them. Hopefully they are now available. A part number would be great.
Rod
