Re: Paging Dr J, Paging Dr. J...(Bryce Mulvey)
[Re: J_BODY]
#1689248
10/26/14 12:52 PM
10/26/14 12:52 PM
Posts: 3,396 Pa
Hot 340
Pa
https://www.facebook.com/bryce.mulvey
nothing on facebook since may...... but maybe some of his friends will give up his whereabouts.
That marital situation must be working him over good. Half the guys I know would say he's living their dream...getting divorced and going racing at the same time.
[Re: pittsburghracer]
#1689249
10/26/14 01:11 PM
10/26/14 01:11 PM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
Divorce or no divorce, avoiding phone calls and contact with people you owe money/ services to is being a dirt ball. Life goes on, stealing money isn't excusable under any circumstances.
[Re: Triple Threat]
#1689257
10/27/14 05:01 PM
10/27/14 05:01 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
there is hope for smallblock people even if the dr. j guy dropped off the map
http://www.forabodiesonly.com/mopar/showthread.php?t=289695
contact MRL have them port you a set of procomps when they ship the next batch
one guy has already track tested the build
670hp is pretty decent out of a small block
Yes, but a 3500# car with "670hp" Should trap a lot faster than 122, especially with a stick.
Hit the nail on the head!
Not the first time that some rather large HP numbers didn't MPH anywhere near what they should. 670hp at 3500 is 130+ on a bad day. 135ish with a good setup. One was a 580ish HP, 3000# and barely cresting 120. Not a fricken chance when there are a bunch of 500hp cars at same weight running better general numbers.
[Re: Triple Threat]
#1689258
10/27/14 07:48 PM
10/27/14 07:48 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
At that weight and mph it is closer to 500 hp.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: 74yellowduster]
#1689260
10/28/14 12:07 AM
10/28/14 12:07 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Our W5 416 may have been tickling that number. Best was 9.87 @ 138 in our Duster.
[Re: DconD100]
#1689261
10/28/14 12:51 AM
10/28/14 12:51 AM
J_BODY
aZLiViN
Well, hopefully he turns up some time...he has $2500 dollars of my money that I paid him in January, and have not heard a peep from him since! I even got his cell phone number from a friend of his brother, but can't get him to return a call or email. I may have to use some vacation time to make a trip to California to see about getting either my heads, or my money back.
here's a pict of the street stock you sponsored:
[Re: DusterDave]
#1689263
10/28/14 01:31 AM
10/28/14 01:31 AM
RobX4406
I LOVE dyno tests that have disappearing horsepower when and IF a car ever hits the track.
There's a member on here(won't mention who) that claims 1,000 hp on the engine dyno, yet can't get the car to run quicker than 10's in the 1/4.
Pass Time was great for the 800hp cars running 10.90's with no stop.
[Re: RobX4406]
#1689265
10/28/14 10:08 AM
10/28/14 10:08 AM
Posts: 167 maryland
74yellowduster
maryland
yeah, but in the engine's defense correct me if i'm wrong, but '75 a bodies are heavier then the earlier ones. he has upgraded to a dana add 75lbs 9" slicks... manual shift. who knows what clutch he's running does he even have a blowproof bellhousing or is he running the cast iron stocker. not sure what other addons he put on the front to add weight and take hp.
but i was just sayin the procomps can be made to run and are a good option. probably not so hot out of the box, but prepped you can make some serius powers
dr. j can go play in some dirt
