Re: Aluminum BB Cylinder Head hierarchy
[Re: Digger73]
#2110641
07/15/16 05:37 PM
07/15/16 05:37 PM
hustlin hoosier
Indy has a new 600-13x head on the shelf now. The head was developed by Goodwin competition and Best machine. the new head fits a 4.840 block, flows 520 cfm @ 1.00". Indy makes the head and Goodwin does the porting. We run the prototype in in a 88 mustang, they are not as good as the new head will be , as we are still revising the exhaust port. That will be done by the end of July. When they are complete we will build a 632" motor to run in mx235. With the 565 motor we are presently racing we go 5.00 at 2950 on 26 in tires. It makes 1222 on a very tight dyno. If anyone is interested they should talk to Chuck at Best Machine 1 248 987 6038.
[Re: Kenny705K]
#2111015
07/16/16 09:52 AM
07/16/16 09:52 AM
Posts: 1,505 TN
SCATPACK 1
TN
Kenny that Valiant looks awesome. I have always been a fan of that early year Valiant body style. Jerry
Old Geezer Racing
[Re: madscientist]
#2111018
07/16/16 10:03 AM
07/16/16 10:03 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Cab you left out Indy 600-13, 572-13, Brewer and Zeeker. Well Brewers if they will hold water and Zeekers if you can find them. But they are also options from best to least. Have you used/flowed the Brewers? I hear how great they are...but I never see them...and just by looks ( I would flow them for FREE to ANYONE who has one available) they are not impressive. Especially for engines over 500 CID. The CSA looks way too small to do much. I haven't read through this thread,maybe Vern has posted with his best Brewer results. He made somewhere over 1140 hp with a 604 cube motor.
[Re: Digger73]
#2111775
07/17/16 02:13 PM
07/17/16 02:13 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
At the risk of sounding naive. What is the pecking order of the available BB aluminum cylinder heads? Starting with the best and working down to the worst. I have been just a bit confused by all of the offerings now.
I am just trying to sort out the performance level of the heads that are on the market. I see several heads from the different vendors and just wonder where they all fit in with each other. I guess I should have asked for the list of the most power potential to the least. I am not looking for any recommendations just an FYI list.
When this thread started 2 years ago. I thought it was a great idea, and quite frankly I still do. I'm confused as to why we can have a 25 page discussion on one head, but this list never got any traction. I know I would appreciate more comparisons from the people with first hand knowledge of the strengths and weaknesses of each offering. The Definitive, Emperical list of BBM Wedge Aluminum Heads 1. Indy Predator Non-traditional valve layout, once considered sacrilege is actually a major plus. Valves as long as your forearm. Pricing info anyone? Or is this one of those, "If you have to ask, you can't afford it upgrades". 2. B-1 TS The TS stands for "Trick Stuff" that you aren't smart enough to figure out. Like a Max Wedge, aluminum front end Dodge of the 60's, they won't even let you touch them until you have major racing cred already. 3. B-1 PSO Unlike the first two listings, I've actually seen a set of these, held them in my hands and inspected them. It took twenty minutes in a cold shower to get my heart rate back to a manageable condition afterwards, but I survived. 4. B-1 MC I've had the opportunity to buy a few pairs of these, ported, used, for around what I normally give for two sets of Indy -1s. I'll continue later, but the Wife just came home, and she's looking over my shoulder... I considered starting from the bottom, more of my domain, but the the list of 210cc/ 70 cc stock knock-offs is getting very convoluted...
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: Kenny705K]
#2111892
07/17/16 04:56 PM
07/17/16 04:56 PM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
I know this is an old post, but I haven't been on the site in a LONG time haha....Looking over a lot of great topics by all you guys. After reading a lot about people's opinions on all the "Mopar" heads, I think a lot of you guys are underrating some of them. Seems a lot of people don't think highly of the 600-13 heads. But, I can tell you that our Valiant at about 2,600-2,700 pounds ran a 7.40 @ 187 m.p.h. with a naturally aspirated 622 with these heads. And that was without ever pushing it to it's max, this was with never once changing jets or timing and running it fat and trying to run a 7.60 index. The chassis is mild steel and not legal to go faster than 7.50. I will have to get back to you on any possible flow numbers, but obviously these have had a lot of work done to them, and the guy's that built the motor don't give Indy too much credit for any help at all. Being good friends with the Renteria's, during that period Tom,Mike,shawn and dusty got zero help from Indy with issues that came up building that 622" motor.... Those heads were done by Al Dixion (HRD ) and were worked heavily in the combustion chamber and ports..... those heads flowed right at 505 cfm 1.00" that was a number that Indy couldn't even get close to touching back then.. Russ and ken wanted to get there hands on those heads to copy for quite a while........
[Re: boatracer572]
#2113110
07/19/16 10:55 AM
07/19/16 10:55 AM
Posts: 51 Vacaville, Ca
Kenny705K
Vacaville, Ca
Hustlin Hoosier - That is pretty impressive. I have seen something about 600-13x but didn't really know anything about them.
SCATPACK1 - Thank you, I love it too
I thought TS stood for "Totally Serious". We have a 499 ci B1-TS motor that we tried running for a while. Because of the design and rpm it killed valve springs though. But, talk about some badass heads those things flowed 540 cfm. We were considering using a different block and making it into a 632 but probably aren't going to go that route. We might be selling that engine soon. Boatracer, yeah I remember all the trouble they went through building that 622. Sure is a great motor though. I would love to get it back in the Valiant someday if my Dad and I can afford it and get some things taken care of
[Re: Digger73]
#2113125
07/19/16 11:24 AM
07/19/16 11:24 AM
MoparBilly
Phoenix, AZ
Kenny, Sorry if I have confused you and Monte...I have a tendency for tongue in cheek sarcasm. I was trying to get a list actually started, hoping that we could get all the pieces on the playing field before we started moving them around.
What I was trying to point out is that even though many of these heads have been around forever, guys like me are fairly ignorant as to what it takes to put them to good use.
That Valiant may just be one of the coolest race cars on the planet, but I'm sure you know that already!!
[Re: Digger73]
#2113871
07/20/16 10:38 AM
07/20/16 10:38 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
Kind of lost this topic..., but I took the Brewers in to a flow bench. Have no idea about the quality of the porting done to them and not going to publish any numbers since they only relate to that flow bench, but they were better both on intake and exhaust than a set of ported B1 MC's and about 20% better than our previous "fully ported" 440-1's I had in the same bench previously. And that's with way less CSA. They actually did have a water leak in the pushrod hole area that I fixed with some epoxy stuff but will fix it better later. Have not yet run the engine but will get it done and dynoed during next winter. Here is a pic of the Brewer next to an Indy 440-1
Plynouth VIP '67 TT IC EFI
[Re: MoparBilly]
#2113891
07/20/16 11:09 AM
07/20/16 11:09 AM
Posts: 803 Idabel,Oklahoma
Gary Robbins
Idabel,Oklahoma
That Valiant may just be one of the coolest race cars on the planet, but I'm sure you know that already!! Billy...I will find out soon if PSO's are worth the coin as mine just got back from Slawko's for the initial cnc work...Will be taking them and my current B1 engine to Glen & Kevin Self Racing for their magic very soon !! Moving to PSO's is not cheap and is gonna be interesting to see how they stack up against my originals as they make some steam !!
[Re: Digger73]
#2120367
07/29/16 02:43 AM
07/29/16 02:43 AM
Posts: 774 Midland,Tx
wyldebill
Midland,Tx
I have an nos set of the last production run brewer head. Pulled them out of the box and cleaned up the entrance to the port. Literally just squared the port. Under 10 minutes. With the 2.25 valve on a stingy bench head flowed 420cfm @ .650
Looking for any other brewer parts out there
