Re: BIZARRE Problem With A 2003 Cummins Ram.
[Re: WayneM]
#1688584
10/24/14 08:49 PM
10/24/14 08:49 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Please explain how I'm nuts? I work on these trucks everyday. I have done this many times to quickly find a fuel in oil problem. Other than taking all of the injectors out and sending them off to be checked there isn't much he will be able to do. He might be able to dye the fuel and use a blacklight, but you are still going to have to run the engine with valve cover off to see the problem. Please keep in mind the OP's relative is somewhere that there is likely no place that he can take the truck to be fixed.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
