Re: CalTracs/Drag Radials and a 4 Speed
[Re: StealthWedge67]
#1688242
10/21/14 10:39 AM
10/21/14 10:39 AM
Posts: 240 Ft. Wayne, IN.
QTR MILR
Ft. Wayne, IN.
From watching the video it looks like there is not enough travel in the front suspension... Calvert will tell you that you need at least 5" of travel in the front. Tighten the rear shocks and getting some travel in the front will surely help a bunch.
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
[Re: 1967dartgt]
#1688245
10/21/14 12:39 PM
10/21/14 12:39 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
Wow good looking dart!! That is what my car looked like when I got it. Just had a vinyl top. Good luck with it.
Thanks Brad. It's morphed quite a bit. The next stage should be good. matt
BTW: Anybody have a quarter panel "T"?
[img] [/img]
[Re: clonestocker]
#1688246
10/21/14 01:42 PM
10/21/14 01:42 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
If I can find it. I took them off my car. I will look and let you know
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 6PKRTSE]
#1688249
10/21/14 07:49 PM
10/21/14 07:49 PM
Posts: 104 Washington
weedburner
Washington
Yeah, Drag Radials & sticks do not go together all that well. Radials like to stay planted & are not forgiving like a slick. You can tune it eventually to get it to some what work.
A clutch slipper can really help make drag radials compatible with a manual trans. Just an extra 1/10th of a second of clutch slip can reduce the drivetrain's shock from clutch engagement by appx 50%.
Here's a link to a very effective clutch slip controller that you can put together for under $50... DIY clutch slipper
[Re: weedburner]
#1688250
10/22/14 04:22 AM
10/22/14 04:22 AM
Posts: 9,108 Rogue River, OR
Jeremiah
Rogue River, OR
FYI you will need a shorter cylinder if you want to hide it under the dash of an a or b body. Works good on the street also! I suggest calling M&H for drag radials on a stick car.
