1968 440 block with a blank VIN pad ?? #1687498
10/18/14 09:36 PM
10/18/14 09:36 PM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
Last week I dragged home a 67 Chrysler 300. I thought it had its original engine but the 4-4-68 casting date told me that it was a replacement engine. Now I started looking at the ID numbers and have found that while there is a machined flat spot on the RH side of the block near the oil pan rail, there is no number stamped there.
The raised pad near the distributor reads D440 6 21 HP with a sideways B inline with the LH side of the block.
Maybe a warrantee replacement? What does this do for the value as compared to another block with an actual VIN stamp?
Re: 1968 440 block with a blank VIN pad ?? [Re: Kern Dog] #1687499
10/18/14 09:48 PM
10/18/14 09:48 PM
katakan
lilred Offline
lilred  Offline
katakan
In 1968 the vin was stamped at the rear of the block close to the oil pressure sending unit where the block and trans meet, if I recall correctly it was the complete vin not just the sequence
Re: 1968 440 block with a blank VIN pad ?? [Re: Kern Dog] #1687500
10/18/14 09:49 PM
10/18/14 09:49 PM
68gtx Offline
68gtx  Offline
I think in 68 the vin# was stamped on the LR of the block close to oil sending unit?
Re: 1968 440 block with a blank VIN pad ?? [Re: 68gtx] #1687501
10/18/14 09:51 PM
10/18/14 09:51 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
So I guess I need a mirror to see it unless I pull the engine. Great!
Re: 1968 440 block with a blank VIN pad ?? [Re: Kern Dog] #1687502
10/18/14 09:56 PM
10/18/14 09:56 PM
katakan
lilred Offline
lilred  Offline
katakan
Just look from the top of the engine Maybe lay on top of the engine and look down you should be able to see the numbers
Re: 1968 440 block with a blank VIN pad ?? [Re: Kern Dog] #1687503
10/18/14 10:38 PM
10/18/14 10:38 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
What difference does it make if you can see the VIN ?? It's not the original engine in the car obviously.
You don't have to pull the engine, or use a mirror, spray the area down good with brake parts cleaner, or hit it with a pressure washer, lay over the top of the engine while shinning a light down there and see what you can see ...
As far as warranty replacement goes, it seems to me that there are more warranty replacement engines out there than Chrysler actually changed under warranty ...
Re: 1968 440 block with a blank VIN pad ?? [Re: lilred] #1687504
10/18/14 10:41 PM
10/18/14 10:41 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Here's a non-matching pair of engine & transmission stampings for 1968.
Re: 1968 440 block with a blank VIN pad ?? [Re: JohnRR] #1687505
10/19/14 12:03 AM
10/19/14 12:03 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
"What difference does it make if you can see the VIN ?? It's not the original engine in the car obviously."
No need to be rude.
My point was that a VIN stamping might shed light onto the original car the engine may have been installed in. There have been stories where people spend years looking for their original engines.
Re: 1968 440 block with a blank VIN pad ?? [Re: Kern Dog] #1687506
10/19/14 01:10 AM
10/19/14 01:10 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Well we're waiting!! What numbers did you find?
Re: 1968 440 block with a blank VIN pad ?? [Re: 6bblgt] #1687507
10/19/14 01:34 AM
10/19/14 01:34 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Either the numbers near the bell are filled with gunk or they are not there. I scraped but didn't see anything. I'll try again and report back.
Re: 1968 440 block with a blank VIN pad ?? [Re: Kern Dog] #1687508
10/19/14 01:46 AM
10/19/14 01:46 AM
It seems to me that all the 1968 wedge motors had the VIN stamp on the top of the motor like shown and stamp on one of the ears supporting the outside tranny bolts by the starter or the other side Either way a warrenty motor won't have a VIN number stamp on it, my 1970 V code Charger had a warrenty motor in it with a casting date of 4-19-1970 and the car had a schedule assembly date in late Oct 1969
Re: 1968 440 block with a blank VIN pad ?? [Re: Kern Dog] #1687509
10/19/14 01:51 AM
10/19/14 01:51 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
So if there is a pad machined on the right side of the block near the oil pan rail that would be unusual for a 68 engine...
JB Rhinehart, Realist
A-Body's RULE!
Re: 1968 440 block with a blank VIN pad ?? [Re: Cab_Burge] #1687510
10/19/14 01:54 AM
10/19/14 01:54 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Not all 68 motors were stamped back there, I would expect an HP motor to be stamped though. I pulled a 68 383 2bbl from it's original body , I still have the block, no VIN stamped on it.
A warranty motor shouldn't be stamped like a Production line motor , unless it was a complete motor pulled out of a line of pallets headed to an assembly plant. A motor would have to be much pretty blown up to get a full engine replaced.
Re: 1968 440 block with a blank VIN pad ?? [Re: Kern Dog] #1687511
10/19/14 01:57 AM
10/19/14 01:57 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
No need to be rude.
It seemed to be acceptable for Hill ??
There are no records for 68 , best you will get it a platform or model line it COULD have been in depending on the build plant, but there are a few members that seem to be able to come up wit ha model fairly often ???
68 440 HP ??? GTX, Coronet R/T, Charger R/T or a C barge that was available with an HP 440 ...
Re: 1968 440 block with a blank VIN pad ?? [Re: JohnRR] #1687512
10/19/14 02:01 AM
10/19/14 02:01 AM
USA
rftroy Offline
rftroy  Offline
USA
I used to own a '68 383 Dart. The block had no VIN stamping. At the time I knew a guy with a 383 68 Barracuda; his engine also had no VIN stamping. I have a 383 block in my garage right now, which was pulled from a 68 383 Dart, and is slated for my 68 383 convertible. It also has no VIN stamping.
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: 1968 440 block with a blank VIN pad ?? [Re: rftroy] #1687513
10/19/14 02:05 AM
10/19/14 02:05 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I am rebuilding a 383 out of a 68 Dart GTS right now and it has the VIN stamped on it like the picture shown above.
A-Body's RULE!
Re: 1968 440 block with a blank VIN pad ?? [Re: Rhinodart] #1687514
10/19/14 02:08 AM
10/19/14 02:08 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Re: 1968 440 block with a blank VIN pad ?? [Re: Rhinodart] #1687515
10/19/14 02:11 AM
10/19/14 02:11 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1968 Model year: engines & transmissions
340s VIN stamp
HEMI VIN stamp
383 4bbl VIN stamp
440HP VIN stamp
440 NO stamp
383 2bbl NO stamp
318 NO stamp
273 NO stamp
/6 NO stamp
Re: 1968 440 block with a blank VIN pad ?? [Re: JohnRR] #1687516
10/19/14 02:12 AM
10/19/14 02:12 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Here is a 440 out of a Mr. Norms 68 Dart GSS with the VIN on the bellhousing rail too... (if only I could learn how to use a camera)
A-Body's RULE!
Re: 1968 440 block with a blank VIN pad ?? [Re: JohnRR] #1687517
10/19/14 02:14 AM
10/19/14 02:14 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I scraped a bit more and found a number right where it was suggested. I'm more familiar with 1970 and later engines so it was news to me that a 1968 engine would be stamped in such a strange area.
My numbers came up 8A333528 .
Thanks for the info. NO I will not delete this thread. I'm trying to be less rude than I used to be.
