Re: Fresh off the dyno!! My Max Wedge results [Re: Thumperdart] #1687061
10/18/14 08:23 PM
10/18/14 08:23 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Hey Cab, send me your metering blocks and I`ll clean up the low speed/cruise and maximize the wfo.............
I have some you can work on??? lol
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Fresh off the dyno!! My Max Wedge results [Re: mopar65] #1687062
10/18/14 09:12 PM
10/18/14 09:12 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Let`s do it man..............
Re: Fresh off the dyno!! My Max Wedge results [Re: Thumperdart] #1687063
10/18/14 09:40 PM
10/18/14 09:40 PM
mopar65 Offline
mopar65  Offline
i don't want to mess up the op post so i will send you a pm latter tonight.thanks Mopar65
Re: Fresh off the dyno!! My Max Wedge results [Re: mopar rookie] #1687064
10/18/14 09:42 PM
10/18/14 09:42 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Lots of HP in getting the carbs jetted correctly with a factory crossram.
conventional thinking on jetting gets thrown out the door with a factory crossram
Re: Fresh off the dyno!! My Max Wedge results [Re: mopar65] #1687065
10/19/14 12:06 AM
10/19/14 12:06 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You`re right...........not cool.
Re: Fresh off the dyno!! My Max Wedge results [Re: nss guy] #1687066
10/19/14 01:37 AM
10/19/14 01:37 AM
Both of my M.W. cars like different jetting, one had the 3447s and the other had the bigger 3705s, totally different jetting on both with stock M.W. intakes
Re: Fresh off the dyno!! My Max Wedge results [Re: Cab_Burge] #1687067
10/19/14 01:31 PM
10/19/14 01:31 PM
central ohio
mopar rookie Offline OP
central ohio
I knew I was sacrificing HP with the stock port intake but that was the look I wanted for my car. I,m gonna kill it more with the stock ramhorn exhaust manifolds as well. I am going to use the exhaust with the dumps like the factory did. There is more tuning to be done for sure.
Re: Fresh off the dyno!! My Max Wedge results [Re: mopar rookie] #1687068
10/19/14 04:02 PM
10/19/14 04:02 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
If you do some searching on the internet there is a build where they dynoed a max wedge build with the small port a&a intake. They dynoed it with headers and manifolds. Headers increased hp like 12-15 and they moved the torque peak down about 1000 rpm. Torque numbers were real close the peak just came 1000 rpm higher with the manifolds. Wondering what your cam specs look like. Looks like that monster will pull a 3.23 - 3.55 gear and still be awesome on the street and strip.
Getting old just means you were smarter than some and luckier than others.
