Re: 99 dodge ram 5.9 gas real world mileage with superchips
[Re: HotRodDave]
#1685388
10/18/14 03:26 PM
10/18/14 03:26 PM
Posts: 6,017 Salem
Grizzly
Moparts Proctologist
Salem
I'm sorry but I'm going to have call bs on this too.
I hypermile the crap out of my '01 360 4x4 1500 w/ 4.10's and the best I can get is 18 at 50 to 55mph. The converter is chopped out, it has a Flowmaster 40 and an electric fan.
Also I would have to see this 3/4 ton "spin the tires" (on dry pavement, I'm assuming) to believe it.
4.10s are killing you, running around with no load is making the engine fight vacuum to pull the piston down and friction is a lot higher. It is pretty funny to hear some put hyper-miling and 4.10 gears in the same sentence
At 55 I'm only turning 1700 rpm with 285 rubber. RPM wise, that's as good as it gets for the beer barrel and I'm at the lowest wind resistance that traffic behind me can tolerate.
If I had 3.55's I'd have to wind it up to 65-70 at which point the air really starts to catch a 5600 pound, 6 foot tall truck. Fuel mileage would be worse and it would downshift on anything but level ground.
I had 3.55's in a regular cab SB 2wd with a 318 and it could barely equal the mileage I'm getting with this one and had no off-line power at all. Non Magnum engine however.
After all the Dodges I've owned one thing is always the same: anything over 60 mph and you take at least a 3mpg hit; more like 5mpg.
I don't know how they do it, but the gms' I've owned, maybe 1, 2mpg penalty at the most.
360View has been through this in great detail, and I've taken alot of his suggestions on here over the years. The best one he gave was to keep the throttle blades as far open as you can without downshifting (on hills and such) to keep mileage up. It works: the overhead instant mileage reading backs it up too.
Mo' Farts
Moderated by "tbagger".
[Re: stumpy]
#1685392
10/18/14 10:53 PM
10/18/14 10:53 PM
Posts: 550 SW Missouri
moparmandjh
SW Missouri
Wow, superchip the only way around it? I would like to have one but can't justify the price.
American soldiers in battle don't fight for what some president says on tv, they don't fight for mom, apple pie, or the American flag... they fight for one another. -Lt. General Hal Moore
[Re: moparmandjh]
#1685393
10/18/14 11:41 PM
10/18/14 11:41 PM
Posts: 4,255 Canada
WO23Coronet
Canada
I think SCT also offers tuning for Magnums but its at least as expensive. The previously mentioned crank sensor mods would help. I personally can believe the performance gains offered through a tuner for the Magnums, stock they are total pooches. I've had two of them, a 95 ext cab sb, and a 96 ext cab long box and both were gutless, like 0-60 times in the 12 second range (going by a stop watch), for comparison my 05 HEMI QCSB 4x4 (at least a few hundred lbs heavier) does 0-60 in the 7.8 sec range. The Magnum motor itself is good, look at the performance guys get out of stock engines by simply swapping to a distributor and a carb (talking engine swaps here), IMO it's from a decent timing curve. Also, look how fast the 92/93 Dakotas were with the original timing curve, yes alot lighter but c'mon, it doesn't account for the poor performance from later years
[Re: d-150]
#1685395
10/19/14 09:02 PM
10/19/14 09:02 PM
Posts: 1,412 northeast ohio
hulmule
northeast ohio
84 Ramcharger 4x4 360 4 barrel. doing the math ... 10.9mpg ahhhhh . Everyone seems to think that the overhead computer is god. do the math for the people who think that the overhead is gospel . on the average its off 2-3 mpg.
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
