Page 2 of 4 1 2 3 4
Re: NEW Thread for NEW BEST. [Re: Cab_Burge] #1683803
10/10/14 07:49 PM
10/10/14 07:49 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
9.03-9.04 that's hauling the mail i can only dream of those et/mph. Care to share the combo?..............
Re: NEW Thread for NEW BEST. [Re: racerx] #1683804
10/11/14 01:27 AM
10/11/14 01:27 AM
Not to hijack this thread but that car is a 1970 Cuda, full tube chromoly chassis with A arm front suspension, four link in the back with steel double adjustable Koni coil overs, Dana 60 with gun drilled 40 spine axles, 40 spline steel Moser spool with dual Wilwood calipers on the back and single caliper Wilwood disc brakes in the front. The main body and slide off front end is steel, the doors, front and rear bumper, hood and deck lid are lightweight racing fibreglas, Lexan side and rear windows with a lightweight safety plate windshield. Thick main web cold weather 400 block with ductile iron main cap and ARP main studs with a 4.25 stroke Ohio Crank Company crank cut down to fit in the 400,505 C.I. Diamond pistons, Comp Cams custom ground solid roller cam, Eddy Victor M.W. heads and a Indy 400-3 inatke with a AJ Castilini built E85 carb. Mikes Monter glide and Mikes 9 inch converter,removeable trans tunnel, Biondo 400 box and Shiftnoid air shifter and air throttle on it. It weighs 2750 with me in it at racing weight, minus me it weighs in under 2500 lbs It is a very good car, goes staright and repeats times. I didn't biuld it so it has to go I have a new car(1965 Dart 270 back half car that will certify to 7.50 ET) being built and I don't have the room to store two race cars or the desire to race two cars any more
Re: NEW Thread for NEW BEST. [Re: 68LAR] #1683805
10/11/14 03:25 AM
10/11/14 03:25 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
10.99 @ 124.38MPH.
THATS what I'm talking about! A 10 second Street car. Awesome!!
Re: NEW Thread for NEW BEST. [Re: racerx] #1683806
10/11/14 08:44 PM
10/11/14 08:44 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
We were able to drop the 60ft times from 1.38 to 1.34 by reducing air pressure.
We run Good Years 14 X 31 and had been running them at 8.5 LBS. I called Good Year tech and they recommended 6.5 - 7 lbs. We have been reducing pressure by .5 lb.s each time out to see if the car gets hard to handle on the top end. So far, no effect on handling at all, and we are at 7.5 lb.s .
If we get back out 7 lb.s next shot.
Mark
P.S.and we may switch to a Dominator carb and intake.
Re: NEW Thread for NEW BEST. [Re: Hemi Allstate] #1683807
10/11/14 10:21 PM
10/11/14 10:21 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Fishy340 first outing with car!
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: NEW Thread for NEW BEST. [Re: 1967dartgt] #1683808
10/11/14 10:35 PM
10/11/14 10:35 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Thanks Brad and yes it was the first nos pass on the car,we ran another 2 with the same 26 jets and I am very very pleased.
I pulled the cam before even putting the engine in the car and had Paul from IS give me a true nos type cam and I'm glad I did.
neXT outing is Atco and the bigger jets are in it and ready to go being the day I was their it got very damp at night and the track wouldn't let us go
Re: NEW Thread for NEW BEST. [Re: racerx] #1683809
10/12/14 05:45 PM
10/12/14 05:45 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
not a new best et/mph since I'm using a restrictor plate, but a new 60 best @1.29, the best so far by almost .04
Getting a little braver and launching @5000
Going to work on my courage and maybe try a 6000 rpm launch
little skeered of that though
29.5 x 10.5
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: NEW Thread for NEW BEST. [Re: oldiron] #1683810
10/12/14 08:01 PM
10/12/14 08:01 PM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
Our new best is a 4.86 @ 146mph with a 1.140 sixty...All at 3200# on 275 drag radials !!
Re: NEW Thread for NEW BEST. [Re: fishy340] #1683811
10/12/14 08:03 PM
10/12/14 08:03 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Fishy I know this is a small block build care to share et/mph? If it's a grudge car I understand
Re: NEW Thread for NEW BEST. [Re: racerx] #1683812
10/12/14 08:22 PM
10/12/14 08:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My new best for the year, [Email]9.37@142mph![/Email] 1.28 60' footbraking!
Randy
That's getting it done my car only went a 1.36 on that 9.51 run............but did a new best 60' of 1.26 this past weekend if I could of ran a better 60'when it ran the 9.50's could have ran that 40 ish..........
Nice.............how`d you get the 60 down so much?
Thanks! Put a newer set of tires on it and played with the shocks some. It seems like we are finally getting a handle on it.
Randy
Nice for both of you guys..............
That's what I'm doing new tires/shock adjustment. Trying to run more air in these new M/T slicks.
Lots of testing I know. Where r your tire pressures now? I`m curious about what my 29x10.5`s will want...........
With these new M/T they recommend 12 lbs min. at 3100 lbs. So i'v started there and went up i'v also been playing around with shock setting. I was right at 13 lbs when it 60'1.26.
Thankxxx I agree at the slightly higher pressures these days and I think 13 lbs. is a good starting point based on how it sits on the ground but we`ll soon see.............
Re: NEW Thread for NEW BEST. [Re: racerx] #1683813
10/12/14 09:13 PM
10/12/14 09:13 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
No prob 1.33 60' 5.63 @ 124 with not so much a click to the Santuffs or Caltracs on a 26jet.
Should go like a sob with 36 and up jets.
Brads iphone films like a potato chip.:) but you can see how tight we had the limiters and how good they work for now
Re: NEW Thread for NEW BEST. [Re: fishy340] #1683814
10/12/14 11:52 PM
10/12/14 11:52 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
My iPhone videos great, only sucks when you send it to droid!
Re: NEW Thread for NEW BEST. [Re: Thumperdart] #1683815
10/13/14 03:45 PM
10/13/14 03:45 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Randy
Randy
I run the M/T 29.5x10.5. I get them used from a local grudge racer. They put 10 passes on them and sell them pretty cheap. Anyhow, with my ladder bar Dart Sport at 3225 lbs we found that the car likes 12-12.5 lbs. And Racerx, that 1.26 is awesome! You'll get 40's out of it for sure !!
Randy
Re: NEW Thread for NEW BEST. [Re: Dartin] #1683816
10/13/14 09:45 PM
10/13/14 09:45 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I bought a set of take off 10.5 x29.5 from the same guy as Dartin. Put them on my 64 Belvedere N/SS car, 2 box stock Eddy carbs @ 3345lbs 1.290, 5.79@118.6, 9.127@147.58. The tires lowered the mph a tad but the early end of the track continues to get better. Considering the car has 185 passes and started at 9.42@143 last spring I'm pretty happy. The converter, engine, cam timing, lash have never been messed with. All tuning done with trans component lightening, shock/ladder bar/tire psi tuning. Even won a couple. Looking forward to next year.
Doug
Re: NEW Thread for NEW BEST. [Re: dvw] #1683817
10/14/14 12:32 AM
10/14/14 12:32 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Just went 5.63 @ 123 at a realitively slow track with a tenth in the timer for the launch control. I figured it would have been a solid mid 5.50 hit
5.53 @ 125 1/8th on the launch control..more left in her!
Re: NEW Thread for NEW BEST. [Re: dvw] #1683818
10/14/14 08:39 AM
10/14/14 08:39 AM
tboomer Online work
tboomer  Online Work
That is great Doug! I wish my junk was that nice!
Re: NEW Thread for NEW BEST. [Re: tboomer] #1683819
10/14/14 10:46 AM
10/14/14 10:46 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
A pass in August this year.
Re: NEW Thread for NEW BEST. [Re: 1967dartgt] #1683820
10/14/14 10:48 AM
10/14/14 10:48 AM
Dartin Offline
Dartin  Offline
Nice!!!
Randy
Re: NEW Thread for NEW BEST. [Re: Dartin] #1683821
10/14/14 04:26 PM
10/14/14 04:26 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
My new best came in the spring on the first day tuning my e85 carb, 10.54 @ 125.6mph. Since then I have tuned the carb, but the air has not been good so I haven't improved...but next spring I would think it would run a 10.4x in cool air without any trouble.
410 small block, ported Edelbrocks
small street roller (248/254),
Victor intake, 750dp carb on e85,
3200# street car, through the mufflers,
727, 8" converter, 4.10 gears, 275/60/15 radial.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: NEW Thread for NEW BEST. [Re: 1967dartgt] #1683822
10/14/14 09:51 PM
10/14/14 09:51 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
67 dartgt I always admire your car i'v seen bit and Peases of that dart but never a full body shot seems like a well thought-out combo.
Page 2 of 4 1 2 3 4
