Re: Debating moving battery to trunk , advantages? [Re: D-50] #1683437
10/08/14 09:42 PM
10/08/14 09:42 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Can you lower the rear? That's where I would start.
Tires inside the wells and drop it down.
Looks like it raises the front OK.
I had the same springs on my Demon and it raised the rear to high for me and I put 2 in. lowering blocks under it and it made a big difference. I had a best 60 ft. of 1.36 on a 100 shot NOS it was spinning before I did that.
Looks nice
When I had the stock rear springs on the car it sat about like your Demon. Problem was on the street every decent bump I hit smacked the tires...... Not good
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Debating moving battery to trunk , advantages? [Re: B3422W5] #1683438
10/08/14 10:35 PM
10/08/14 10:35 PM
jersey
Spaceman Spiff Offline
jersey
Put mine where the spare tire goes....
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Debating moving battery to trunk , advantages? [Re: Spaceman Spiff] #1683439
10/09/14 01:26 AM
10/09/14 01:26 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
When I did a mild restoration on my 63 I put the battery in the trunk since some Max Wedge cars were like that. Myself I like it in the trunk as it gives that extra room under the hood. And since I drive my car alot I put my battery in a case as not to get acid on anything I put back there. But when it came time for the cutout switch I was not going to drill a hole in my car so I ended up drilling a hole in the drivers side taillite lens and the rod for the switch goes thru the taillite lens. I have extra tailite lens if I ever change it back but I dont intend too. So myself I like my battery in my trunk. And in case you ask the battery is on the drivers side because my buddy gave me the cable and it was not long enough to reach the pass side in the trunk. I know they always go on the right side but hey its a street car and it works fine over on the left side and I did not have to buy any more cable. You can see the shut-off switch rod sticking out of the left rear taillite. To bad it could not be off when pushed in where it looks better but who ever saw a cut-off switch that says.......pull to cut-off ? Ron
Re: Debating moving battery to trunk , advantages? [Re: 383man] #1683440
10/09/14 02:24 AM
10/09/14 02:24 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I moved my battery to the trunk a while back and I'm glad I did it. I like extra room and clean look under the hood, and it lends some weight to the "strip" side of the "street / strip" vibe I'm going for. I used 1g cable on the hot side, and 2g on the neg. side, with a heavy duty waterproof Summit rotary switch at the bumper just to the right of the license plate. I also used a Taylor vented stainless battery box so I'll never have issues at tech.
I don't know that I needed the weight transfer advantage in an 11-second car, but it does hook with no issues.
Re: Debating moving battery to trunk , advantages? [Re: 383man] #1683441
10/09/14 07:15 AM
10/09/14 07:15 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Beautiful pic of your car, Ron.
Re: Debating moving battery to trunk , advantages? [Re: Leigh] #1683442
10/09/14 08:29 AM
10/09/14 08:29 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If it's going in the back, put it as far right and rearward as you can get. These cars are always nose and drivers side heavy. The closer you can get the right rear to the left w/o jacking the suspension the better. As for those tires, they'll work w/o issue when sorted out.
Doug
Re: Debating moving battery to trunk , advantages? [Re: B3422W5] #1683443
10/09/14 08:29 AM
10/09/14 08:29 AM
MD
Kevins493 Offline
Kevins493  Offline
MD
I just went through a lot of this with my street car. I run an iron headed 408 in a 3650+lb challenger (et's are in my sig). I left the battery in the stock location just to keep the engine compartment looking stock-ish. Doesn't seem to hurt the car since it will 60' consistently in the mid-high 1.50s. If you are not trying to keep the stock look, there is no reason to keep the battery in the engine compartment. It takes up space, and I have to imagine it will live longer when subject to less heat.
I HATE power steering in any car other than my daily driver. I put manual steering in this car when we first built it 10 years ago and have never once wished it had power steering. If it has power brakes, swapping to manual will open things up as far as cam selection (don't have to worry about vacuum). I run a 42GPH Meziere pump with a 4 row copper radiator and it doesn't go over 195°F idling in traffic on a humid 95° day.
Re: Debating moving battery to trunk , advantages? [Re: B3422W5] #1683444
10/10/14 09:54 PM
10/10/14 09:54 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The physics of moving the battery are more dramatic than they appear.
The front location is forward of the front axle, which means that the 70 lb. battery exerts more than 70 lbs. on the nose - by cantilevering, it removes weight from the rear axle.
The change to trunk mount is exactly the reverse: since the weight is behind the axle (and probably far more distant than the front location) it adds more than 70 lbs. to the rear axle weight since it removes weight from the nose.
The actual numbers can be had by measuring the distance from the center of the battery to the front axle, divided by the wheelbase, and multiplied by the battery (and tray) weight.
Example: if the battery center is 11" ahead of the axle and the wheelbase is 110", the ratio is 10%, so you get an extra 7 lbs. on the nose.
Do it the same way for the rear. The battery center is 20" behind the axle, the ratio is 18.2%, so the change includes:
1. the 70 lb. battery
2. the extra 7 lbs. on the nose
3. the extra 12.7 lbs. on the rear
totaling almost 90 lbs.
The rearward distance also helps prevent weight transfer slightly by increasing the polar moment - the leverage makes the tail end harder to rotate around the axle center.
Boffin Emeritus
Re: Debating moving battery to trunk , advantages? [Re: Leigh] #1683445
10/10/14 10:55 PM
10/10/14 10:55 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thank you. Ron
Re: Debating moving battery to trunk , advantages? [Re: Leigh] #1683446
10/11/14 03:32 AM
10/11/14 03:32 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Yea it is. Ahhhhh...
Re: Debating moving battery to trunk , advantages? [Re: B3422W5] #1683447
10/11/14 06:20 AM
10/11/14 06:20 AM
cudadoug Offline
cudadoug  Offline
I'd lose those 002/003 springs and have the Caltrac/spring deal going on. Yes, taller front tires will help and you'll gain rollout and thus a gain in ET.
About the battery? Here's what I'm going to do in my street/stripper rather than move it to the trunk:
http://performancedistributors.com/product/dyna-batt/
I am old school, my old car ran 9's on 002/003 leafs with a small tire and I could dial the car blindfolded. Not a big cal trac fan. At this current cars power level these leafs are well more than adequate( and I just put them on it) ....lol
Old school is cool, just making a suggestion. But...I can tell you that once upon a time I gained .07 in 60 by adding 2" lowering blocks to the same same springs and going to a 27" front tire from a 25" version.
I wasn't smart enough to know what I was doing ET wise. I just didn't want the John Deere look...
Re: Debating moving battery to trunk , advantages? [Re: polyspheric] #1683448
10/11/14 01:21 PM
10/11/14 01:21 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Assuming your numbers/calcs are correct and they seem to be and I agree with the conclusions, there is another impact to consider besides just a straight line forces one might consider in moving a battery, a rear mounted battery can be mounted often lower, lowering the COG, and if any cornering/handling goals are desired, there are some benefits to be found having a battery in front of rear axle, closer to f/r COG regarding yaw forces.
Re: Debating moving battery to trunk , advantages? [Re: jcc] #1683449
10/11/14 02:31 PM
10/11/14 02:31 PM
Utah, USA
1964superstock Offline
Utah, USA
This all my be true, but if you do it the safest correct way to install a battery in the trunk, it is a ton of work and expensive. I just finished installing a battery in the trunk job, and will NEVER do it again. Unless you are building a drag only car looking for a slight gain in traction, or whatever, I would forget about it. Just install a lightweight battery up front. The actual performance gains with the battery in the trunk for a street/strip car are very little in my opinion, mostly for looks, but a huge PITA. My opinion since you asked.
Re: Debating moving battery to trunk , advantages? [Re: B3422W5] #1683450
10/11/14 03:13 PM
10/11/14 03:13 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I would be interested in how much all that extra cable weighs.
Re: Debating moving battery to trunk , advantages? [Re: B3422W5] #1683451
10/11/14 04:38 PM
10/11/14 04:38 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Street/strip car here, my battery is in the trunk. Taylor 4 pole switch under the r/s bumper. Bought the car with it like this but completely rewired it after I went to an internally regulated Denso 60a alternator.
Went through a lot of jive to get it wired right with a cut off switch and alternator. Ended up using two solenoids, one for the long positive cable so it's 'only hot when cranking' and one continuous duty solenoid for the alternator so the switch turns it off. All my dash wiring goes through the disconnect too.
Ran my big B+ wire through the wiring trough on the driver's side and under the carpet. Goes through a grommet in the firewall and to the starter. I used a second relay up front to activate the starter with the ignition switch. Was a little complicated but it works.
I used a 'buss bar' from Mad Electrical on the firewall to tie things together that go from the front to the back. Works good and provides a spot for B+ when the system is on. Things like test equipment, timing light etc.
I have a couple #4 ground wires too, one bolted from the back of the r/s head that goes to the front sub frame and one from the battery to the rear chassis.
I have a few pics if needed.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Debating moving battery to trunk , advantages? [Re: RMCHRGR] #1683452
10/11/14 05:14 PM
10/11/14 05:14 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I would do all those mods and not even think twice. The weight of the cable isnt that much and being towards the back doesnt hurt. I also wouldnt hesitate on the elctric water pump, There is nothing better in my opinion. They cool the car good and when you shut it off at the ice cream shop you dont have to get back in with 230 degree temps. As far as cal tracs I think people tend to use them on applications that dont really need them. My car makes pretty good torque and horspower and I just have a set of the xhd springs and a pinion snubber and it hooks on wet grass with 275 drag radials.
67' charger 499 RB 10.57 at 127
Re: Debating moving battery to trunk , advantages? [Re: B3422W5] #1683453
10/14/14 07:49 AM
10/14/14 07:49 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
I run this 75-775, 33 pound battery in our 70 Challenger six pack. Has performed flawlessly, is inexpensive, has side terminals(conceals battery cables very well) and looks great.
http://www.amazon.com/Parts-Master-75-775-Standard-Automotive/dp/B0094H8746
Re: Debating moving battery to trunk , advantages? [Re: forphorty] #1683454
10/14/14 08:20 AM
10/14/14 08:20 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My Optimas weigh 45lbs each. 0/2 copper, not 2/0 was used in my build, it weighed a total of 7lbs. Minus what ever the stock stuff was. Obviously mine is over twice as thick as factory stuff.
Doug
Re: Debating moving battery to trunk , advantages? [Re: jcc] #1683455
10/14/14 08:56 AM
10/14/14 08:56 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
And of course its not just about fore/aft distribution or COG
Placing a heavy battery over or behind the right rear wheel adds ballast where it's most needed - because its the RIGHT side wheel that tries to " pick up" due to the inertial counterforce of the pinion against the crown wheel.
(Same reason a single spinner always breaks the right tyre loose....)
Placing it over the left rear wheel CAN cause more potential loss of traction due to the existing imbalance of downward force between the left and right wheels....but this is when the car is on the ragged edge of tractibility.....
Generally the battery re-location is one of many mods like a snubber, stiffer right side spring, spring clamps and rated shocks that go towards correct weight distribution and achieving separation which the Mopar leaf spring system was designed to do.
Bare in mind...a lot of these adjustments work because the super stockers ran serious overhang behind the wheel arch - a short assed car like our aussie Chargers usually needs some sort of traction bar or Caltrack.
Squatting is for chicks and Chebby owners
