Page 2 of 3 1 2 3
Re: how high can a/have you seen a 440 wind up? [Re: gofastboater] #1681810
10/06/14 01:31 PM
10/06/14 01:31 PM
P
Paul_Fancsali Offline
P
I suspect there is some hot air here 9 and 10K shift points yea my a** these are not sport bike engines Race engine OK but you are not doing this on a regular basis with a big block engine
Re: how high can a/have you seen a 440 wind up? [Re: cdoublejj] #1681811
10/06/14 01:34 PM
10/06/14 01:34 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
how high can a 440 wind up? or how have you seen one go?
They will all rev high once...
...FAFO...
Re: how high can a/have you seen a 440 wind up? [Re: skicker] #1681812
10/06/14 02:07 PM
10/06/14 02:07 PM
dogdays Offline
dogdays  Offline
Dumb question. How high is up?
Stock heads flow something like 228cfm, meaning after whatever rpm it takes to make 480 hp you're just wasting time.
Then there's the block issue. Why pay extra $$$ for a valvetrain fit to go 9000 rpm when the blocks start breaking slightly north of 650hp?
R.
Re: how high can a/have you seen a 440 wind up? [Re: dogdays] #1681813
10/06/14 07:29 PM
10/06/14 07:29 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
We broke a lot of big block Mopars (383s, 400s & a few 440s) turning them a consistent 6,000 rpm in our dirt track cars. The motors were all stock bottom end, and lasted 8 weeks racing (about 3/4 of the season), they were plentiful and cheap, we were broke, I had a source that would sell me used big blocks for under $100 each. Spun rod bearings in most of them. We ruined a lot of good stuff back then. Gene
Re: how high can a/have you seen a 440 wind up? [Re: poorboy] #1681814
10/06/14 09:18 PM
10/06/14 09:18 PM
middle Tennessee
mopower440 Offline
mopower440  Offline
middle Tennessee
We used to turn the 440 weekly to 6800 in the dirt track challenger and never hurt a thing, never lost an engine or anything..bottom end was stock..
Re: how high can a/have you seen a 440 wind up? [Re: mopower440] #1681815
10/06/14 10:24 PM
10/06/14 10:24 PM
I had two occasions that I saw 8400 RPM on my VDO Extreme Playback tach in my old Duster, 518 C.I. pump gas motor Once when I accidently opened the sixpak in the water doing a high gear burnout , the other time was when I broke a trans yoke in 2nd gear at WOT It had all the good stuff, solid roller cam with really good valve springs and all the other good racing valve train parts
Re: how high can a/have you seen a 440 wind up? [Re: Paul_Fancsali] #1681816
10/06/14 10:33 PM
10/06/14 10:33 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
The only hot air would be what was going down the two Doms through the Tunnel ram into the 12.5 to 1 Pistons, Hemi Head 430 Ci balanced big money reciprocating assembly that had 200 Th. cut of the block and ran a 750+ lift roller cam. You have to spend big money to Rev a Motor with smaller CI and make huge power. A stock 440, like I said earlier, it can rev. but the power of a stock type motor is 5500 to 6400 RPM depending on just what 440 you run. The HP fall off after that.
Re: how high can a/have you seen a 440 wind up? [Re: hemicar1971] #1681817
10/07/14 03:21 AM
10/07/14 03:21 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
The 505" in my coronet made peak hp at 6500. I normally shift @ 6500 and it crosses the stripe @ 7100.
505 dyno pull
Re: how high can a/have you seen a 440 wind up? [Re: cdoublejj] #1681818
10/07/14 11:47 AM
10/07/14 11:47 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I used to over rev mine on a regular basis.
After a while, I figured out that all I got was accelerated engine wear.
Internal forces increase by the square of the rpm increase. Double the rpm and quadruple the forces. The internal stress at 8000 rpm is about 16 times the force at 2000 rpm.
That's begging for trouble.
I managed to make good power with the TT440 without revving it to the moon. 657 rwhp came in at 5800 rpm.
If you want to hit a specific mph number then change the gearing and build a stronger engine. It'll last much longer than spinning an engine higher.
- Stu Harmon
Re: how high can a/have you seen a 440 wind up? [Re: feets] #1681819
10/07/14 01:54 PM
10/07/14 01:54 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
AMEN!!!!! I just shake my head at seeing and hearing of people spinning their motors way past the power band. All that they gain is faster wear and broken pieces
Re: how high can a/have you seen a 440 wind up? [Re: MoparforLife] #1681820
10/07/14 02:08 PM
10/07/14 02:08 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Re: how high can a/have you seen a 440 wind up? [Re: feets] #1681821
10/07/14 03:39 PM
10/07/14 03:39 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
DING DING 10 Points Correct answer
MLR426
MLR426
Re: how high can a/have you seen a 440 wind up? [Re: Cab_Burge] #1681822
10/07/14 06:05 PM
10/07/14 06:05 PM
USA MO
cdoublejj Offline OP
USA MO
Are you wanting to know about a stock type 440 or a all out wedge race motor ? If race probally around 9800, maybe a little higher depending on the heads, cam and intake My old pump gas 400 stroker 518 C.I. liked to be shifted above 7300 RPM at the track for the best performance
I was thinking stock block, anything else goes.
EDIT: let me clarify, i do understand power bands and bob weight and what not. at least to a certain degree.
Re: how high can a/have you seen a 440 wind up? [Re: Paul_Fancsali] #1681823
10/07/14 11:08 PM
10/07/14 11:08 PM
moparx Offline
moparx  Offline
with the internal tach switch set on "4cyl", 10k is a piece of cake !
Re: how high can a/have you seen a 440 wind up? [Re: cdoublejj] #1681824
10/08/14 12:32 AM
10/08/14 12:32 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You understand bob weight. Now it's time for a little math.
2700 grams (roughly stock) spinning on a 3.75" stock stroke circle exerts about 11,400 lb/ft of force at 6000 rpm.
That same 2700 grams spinning at 8500 rpm exerts about 22,800 lbs of force. Going up 2500 rpm just DOUBLED the stress from the rotating mass.
Now, that's one hole. When all eight are spinning you can see that things are going to get ugly in a hurry.
- Stu Harmon
Re: how high can a/have you seen a 440 wind up? [Re: Kern Dog] #1681825
10/08/14 12:57 AM
10/08/14 12:57 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
When Rick Ehrenberg was asked this question, he responded with something like....How high? exactly ONE rpm less than it takes to blow it up.
That is my best guess with a question like this,why waste time guessing?
Re: how high can a/have you seen a 440 wind up? [Re: goldmember] #1681826
10/08/14 01:55 AM
10/08/14 01:55 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Seems like he got alot of feedback with that question. RPM = good balance, light rotating assy. good roller cam, good springs,put a brick on gas pedal see how high it will go for how long. Stock untouched heads are only good to 5,500 to 6,000,so many combos to make them better. Where do you want to go and how much money ya gots. And the big question.. WHY.
Re: how high can a/have you seen a 440 wind up? [Re: feets] #1681827
10/08/14 01:35 PM
10/08/14 01:35 PM
Colo
P
PJ68RT Offline
PJ68RT  Offline
P
Colo
Care to elaborate your 'math' on those numbers?
Re: how high can a/have you seen a 440 wind up? [Re: PJ68RT] #1681828
10/08/14 06:48 PM
10/08/14 06:48 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I'm on my cell phone and typing leaves a bit to be desired.
Google centrifugal and centripetal force. There are calculators available.
- Stu Harmon
Re: how high can a/have you seen a 440 wind up? [Re: mopower440] #1681829
10/09/14 09:42 AM
10/09/14 09:42 AM
gregsdart Offline
gregsdart  Offline
Forged 6 pak pistons,6 pak rods, Isky solid cam, .200 valve to piston clearance(very important!)
Missed shift, went to 8700 on the tach. I have no clue how much tach lag there was, It may have gone higher than it showed. I feel extremely lucky those 3/8 rod bolts held up
Page 2 of 3 1 2 3
