Page 3 of 4 1 2 3 4
Re: Where is the big reveal on the killer sb heads. [Re: Leon441] #1681288
10/07/14 01:35 PM
10/07/14 01:35 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
There already is aftermarket heads for Gen III Hemis. Yeah solid roller valvetrain is still in its infancy. The lack of interest in them is what is holding them back. People are scared of change. By the time everyone gets the idea, the aftermarket will have already moved on, AGAIN.
Mopar to the bone!!!
Re: Where is the big reveal on the killer sb heads. [Re: 72Swinger] #1681289
10/07/14 01:46 PM
10/07/14 01:46 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
I'm not scared of change,I just don't want one of them.
Who the hell wants to spend 6 grand on an unmachined alum block and the cost of all the bells and whistles to go mid 9's when it can be done with a stock 340 and procomp heads.
Mopar is out of their minds and trying to force this on their tiny amount of diehard fans.
I know there is a pro charged one in x275 w billed heads,but to be honest it don't compete and cost I bet 60+ grand.JMO
Re: Where is the big reveal on the killer sb heads. [Re: fishy340] #1681290
10/07/14 01:53 PM
10/07/14 01:53 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Why buy an aluminum block when the stock ones can take twice what a 340 can?
Re: Where is the big reveal on the killer sb heads. [Re: 72Swinger] #1681291
10/07/14 02:20 PM
10/07/14 02:20 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I haven't seen the price on used 5.7L Hemi's drop around the DFW area. I thought the cop cars would start showing up in junkyards and the engines would bring the prices down. That hasn't happened as far as I can tell.
I'm thinking Mopar will drop making new parts for the LA and B/RB engines. I think making parts based on production engines will be more cost effective, and as has been pointed out, the Gen3 Hemi is a pretty good base. The Magnum engines and shortblocks were a pretty good deal from MP when they were a production engine. I won't make the switch since I still have a small stack of 340 parts. It will cost too much for me to change now.
Re: Where is the big reveal on the killer sb heads. [Re: fishy340] #1681292
10/07/14 04:21 PM
10/07/14 04:21 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Rob Goss that qualified 4th in GA don't compete? Just a few thou off
Rhodes isn't competing?
Re: Where is the big reveal on the killer sb heads. [Re: Leon441] #1681293
10/07/14 04:23 PM
10/07/14 04:23 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
The gen 3 works. I like the R5 P7 also but if you can only afford a 358" (like I could have bought) it seems like getting the right converter is a nightmare and they want a huge converter, that takes the fun out of driving my car to me. Big W heads it is
A 8" 7000 stall converter for a 800 + HP engine with a 7600-9500 powerband does not stall 7000 at street rpm. I ran one with 4.10 gear a 1.76 first an 33" tires. It was very streetable and got 15mpg. "This is what I call an excuse". If I hadn't tested documented and posted my results, would agree with your issues. But, it is proven not to be an issue.
Moving on....
Gen3 hemi heads do not outflow exotic LA heads.300cfm is not even comparable to 410+. And really a W8 is not exotic anymore. P5 is exotic and their numbers are out of site.
I like the gen3 just like to see people realize aftermarket designs is what is running the big power. Although the built up stock engines are impressive to.
In the past 15 years there have been several sb heads available. They were just more expensive. The edelbocks were priced better but are 38 year old design. The Indy's are also a very old design. Anyone remember Batton? arrignton even made a head for 59 degree blocks. They made good power.
The heads on my 05 Ram will flow 300 cfm with mino work, and they're the bottom feeder as far as Gen III's go. Stock 6.4 heads are 340 ish and over 400 when worked on, so they are well within exotic LA territory.
No hate here for the LA but give the Gen III a little more time and it'll be the obvious way to go
Re: Where is the big reveal on the killer sb heads. [Re: WO23Coronet] #1681294
10/07/14 10:25 PM
10/07/14 10:25 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
I was lucky enough to get 100% of the parts needed for a R5 P7 build From Scott E. but ive wanted to let things go a few years and see how some builds went to decide on mine.
Now the hard part is finding a machine shop within 200 miles of me that can handle the work.
Although I hate to say the open space? block looks like a LS1 in style alone so there should be someplace to do it.
My local napa is good for older blocks and inline 6 tractor blocks as well.
From the static vs dynamic topic I think im in trouble on my current R block build at 13.9:1
Re: Where is the big reveal on the killer sb heads. [Re: SpareParts] #1681295
10/07/14 10:47 PM
10/07/14 10:47 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Frankly the gen 3 stuff I have seen thus far doesn't excite me any more from a performance level than old school LA stuff.... And the gen 3 motors( IMO) don't look as good under the hood.
For a well scienced out bracket type build there is a combo on here that runs 9.60's. It's EFI and done right, with well ported heads and good parts( 426 inches) It runs good, no doubt.
But an Indy head or even W5 motor run just as well. And many actually run much better.
I am probably old fashioned, but the gen 3 doesn't look as cool or run any better and doesn't fit as well either.
P7 deal seems the cheapest way I know to have an easy mid 9 sec combo.
Again I am old... So..
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Where is the big reveal on the killer sb heads. [Re: 72Swinger] #1681296
10/07/14 10:51 PM
10/07/14 10:51 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Sounds nice for the crowd,show me one that handles 1400+.
As a matter of fact show me one n/a that can beat one bad fishes stock block and i'll apologize to all.
Re: Where is the big reveal on the killer sb heads. [Re: B3422W5] #1681297
10/07/14 10:53 PM
10/07/14 10:53 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Like I said look at what the guys with the 4000lb cars are doing on LX forums. Now picture that low 9 set up in a 2800-3k lb car. Gen 3 makes power, I remember Tim Barth making 1600whp with a stock block, lifters and rockers.
I agree that they look out of place.
Re: Where is the big reveal on the killer sb heads. [Re: SpareParts] #1681298
10/07/14 10:54 PM
10/07/14 10:54 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
4th to you for a motor of the money is competing ? I guess purple cams and pinion snubber are here forever lol
Re: Where is the big reveal on the killer sb heads. [Re: fishy340] #1681299
10/07/14 10:59 PM
10/07/14 10:59 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Haven't seen one in an under 3000lb car yet. Don't know what bad fishes car is.
Re: Where is the big reveal on the killer sb heads. [Re: 72Swinger] #1681300
10/07/14 11:17 PM
10/07/14 11:17 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Btw.... Almost forgot....
The " big reveal" if I remember right was teased about on several threads recently by one of our Australian posters. Don't remember which one... Would have to go dig it up
1.41 best 60 foot
6.56 at 104.17
Re: Where is the big reveal on the killer sb heads. [Re: 72Swinger] #1681301
10/07/14 11:24 PM
10/07/14 11:24 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I thought this was a small block head post, not an LA versus Gen3 post?
Keith
Re: Where is the big reveal on the killer sb heads. [Re: Dunnuck Racing] #1681302
10/08/14 03:33 PM
10/08/14 03:33 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I remember a thread about the eddy victor SB head and they said "june" then someone else said they would be revealing another new head all together by the end of that week, still have not heard from either again I say, give us an aluminum W2, Indy is too much money with too low quality, heck pro-comp has less complaints maybe they should do the aluminum W2. A w2 makes plenty of power for the average guy, a little home porting and you can do 600 HP with out fragile max ported stock junk.
I have been keeping mumm about this for a while because every one says all 360 blocks are basically the same but the 5.9 magnum block can handle significantly more power than a 340 block or 92 back 360. A couple things to think about and look at, the pan rail around 2 and 4 mains has a lot more meat, kind of like a TA, and I don't see way better sonic numbers but I bet you would have a lot harder time busting a cylinder wall, try grinding some notches to clearance one for a stroker crank, then try it in the old LA block and see which one is tougher to grind on Not to mention the outer wall is thicker with the extra mount bosses, expecially the 2002-2003 blocks got to help with flexing. Oh and you get a roller cam included with every core, this is the one we need an aluminum W2 for. Go take a look with the two blocks sitting next to each other
Re: Where is the big reveal on the killer sb heads. [Re: fishy340] #1681303
10/08/14 06:53 PM
10/08/14 06:53 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
4 out of 32 of the nations fastest is definitely competing. Rhodes won it, I guarantee his motor isn't cheap. Goes is the fastest small tire Mopar I know of since he's been 4.50's (Rhodes also runs .50's) so I guess I will ask you. What does it take to impress you? How do you define competing?
Re: Where is the big reveal on the killer sb heads. [Re: Dunnuck Racing] #1681304
10/08/14 10:27 PM
10/08/14 10:27 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Keith
Believe it is.... or was. The smell of death in the small block circles in overwhelming. Dinosaur heads, no blocks..... Is that a sunset I'm riding off into?
Re: Where is the big reveal on the killer sb heads. [Re: J_BODY] #1681305
10/08/14 10:38 PM
10/08/14 10:38 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
There are blocks available and I may have one in my black Duster in the near future. I just happened to start a conversation with the right gentlemen at PRP's nostalgia race last weekend. I happened to drop the right name during our talk and had a price the next day. Hopefully i can give out more info at a later date. Possibly a P7 build.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Where is the big reveal on the killer sb heads. [Re: J_BODY] #1681306
10/08/14 11:05 PM
10/08/14 11:05 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Keith
I don't think LA stuff is dinosaur, but it is hard to ignore factory parts that will compete with exotic race parts of a motor from a previous generation...Even more so when the parts from the previous generation are getting harder to come by, and promises for new development never seem to come to fruition.
Oh wait, we're Mopar guys...of course we'll ignore it and acknowledge only the downsides, and the aftermarket of the G3 hemi will never be as good as it could be because of that...I wonder why LS stuff is so cheap and plentiful?
My post isn't directed at anyone here in particular...It is just frustrating that we are promised or told about new LA parts, whatever they may be, are coming, but they don't usually seem to make it to reality...As much as the G3 is awesome, I will probably be racing with an LA for a long while, so it would be nice to see new developments actually hit the market and be worth their weight (there is never anything wrong with options!) ..but with the current trend in LA product development, I wish I started with a G3
Re: Where is the big reveal on the killer sb heads. [Re: mshred] #1681307
10/08/14 11:56 PM
10/08/14 11:56 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
Page 3 of 4 1 2 3 4
