Re: Do MSD boxes or coils give a clue before they quit?
[Re: Mr. T]
#1681088
10/03/14 01:18 AM
10/03/14 01:18 AM
Posts: 345 iowa
wesw
iowa
yep. made a pass and shut it off my digital 7 never worked again. had to buy a 7Al3 from someone at the track to finish the race.
598 ci predator
[Re: bonefish]
#1681095
10/03/14 01:55 PM
10/03/14 01:55 PM
Posts: 5,163 CT
GTX MATT
CT
Not sure, mine just went though. I layed into the car and it broke up, tach bouncing all over the place. Tried to ease into it, same thing. Would rev up clean with the clutch in and ran fine if you drove it easy. Started heading home and made it about a mile before it crapped out. When it died it was actually running, barely, with the tach at 0. Tried to refire, tach bouncing everywhere and ran for about 10 seconds, then died.
Thinking back on it, the car has smelled a little gassy at idle for the past 2-3 weeks and when I got on it with a buddy a few weeks back I swear it broke up and missed a little in first.
[Re: GTX MATT]
#1681096
10/03/14 03:20 PM
10/03/14 03:20 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Just went through the same thing a few weeks ago. Ran fine until under a load. Free revved fine, ran fine in water box...as soon as the motor was under load, it would break up/miss on both sides. The box I had on the car was made in '94 according to the number code on the back. I had another box on my run-in stand that was new in '01. I switched the boxes and coils and the miss went away. I sent the old box and coil back to MSD to be tested together and repaired if needed. I got them back in about 2 weeks. They sent the test papers of both. The coil was OK but the box failed. They put 3-4 electrical components in and re-tested for 2 hours at 4000 RPM...test OK/Pass. Cost with shipping was $61.xx. I had never had a box cause a miss before. Others have told me they had. I had only experienced them just completely failing, as in NO start.
If you like drag racing, support your local track.
[Re: CHAPPER]
#1681099
10/03/14 04:22 PM
10/03/14 04:22 PM
Posts: 5,163 CT
GTX MATT
CT
Got my RMA and am planning to ship it to them this afternoon. Did your tach go nuts too?
[Re: GTX MATT]
#1681100
10/03/14 07:37 PM
10/03/14 07:37 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Back in 08' I bought a brand new Digital 7, it was DOA. I sent it back and they repaired it. Ran a total of about 1/2 hour. Two days later, no spark. No warning on that one. Sent it back again and this time they replaced it. Drove it a couple time this summer, then no spark. Was worried it was the box again, turned out it was the crank trigger PU. No waring on that one either. I think it's an MSD trait LOL
