Re: fast 60 ft, slow mph HELP
[Re: Thumperdart]
#1680625
10/06/14 02:01 PM
10/06/14 02:01 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Have you cut the engine and done a plug check before driving back to the pits to check it's not lean or pig rich.I usually take a spare plug and a small wrench, swap it over and check it in the pits. I also had a problem with my motor laying over and it was the carb too close to the scoop. I ran without the hood and it was back where it normally is. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: sshemi]
#1680629
10/07/14 05:22 PM
10/07/14 05:22 PM
deaks
robin hood country
I went 10.24 at 130 mph in my car with a holley blue, 3/8 line and the small holley reg. Great 60 ft though, best i've ever gone is 1.39. Mick
[Re: sshemi]
#1680630
10/07/14 05:48 PM
10/07/14 05:48 PM
Posts: 11,729 Portage,michigan
B3422W5
Portage,michigan
My holley black is not enough on my car. About 520 hp 408 4 speed 3.73 3780 lbs. It quits at about 5700 rpms in forth. Stock type pick up but 1/2" to 1/2" alu line to filter then an8 to reg then two an6.
I suspect your issue isn't the fuel pump. I ran a Holley black on my 422 small block for years( 650 ish horse) 9.80's at 3350 pounds at 7300-7500 every pass. Swapped to a much bigger system and saw nothing, zero difference. At 520 horse a blue should even likely be adequate. Could be filter, pickup, voltage, regulator...... But that pump should be plenty adequate ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: B3422W5]
#1680633
10/08/14 03:03 AM
10/08/14 03:03 AM
Posts: 2,128 sweden
sshemi
sweden
Forgot to mention i run E85. Filter is on of those inline tubes with a mesh in. Shouldnt restrict much? From filter i have a an8 hose to the regulator witch is the cheap holley modell. After reg i have jegs prebent steel tubing kit. Cant really see the restriction exept maybe regulator.
[Re: deaks]
#1680634
10/08/14 03:06 AM
10/08/14 03:06 AM
Posts: 2,128 sweden
sshemi
sweden
How do you get a sb A body to 3780 # ?
Oh boy here we go again.... It can be done! Im 220lbs. Lots of sound deadener, only lightweight parts are radiator and mastercylinder.
[Re: sshemi]
#1680635
10/08/14 03:18 AM
10/08/14 03:18 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I would agree with others as the Holley black pump should be more then enough for your setup. I use the Holley black pump also and have the regulator press set at 6 psi. I use 3/8 line and a stock fuel tank with a stock 3/8 sending unit. It feeds my car fine as I have no fuel starve problems at all. I actually had the red pump on before and switched to the black just to be sure it was getting enough fuel but it ran the same 10.70's with the Holley red pump also. Ron
[Re: sshemi]
#1680637
10/08/14 06:55 AM
10/08/14 06:55 AM
deaks
robin hood country
When i upgraded my fuel system, the car did pick up. Just curious sshemi. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: B3422W5]
#1680639
10/08/14 10:48 AM
10/08/14 10:48 AM
deaks
robin hood country
According to Wallace. 523 = 120mph 665 = 130mph
