Re: 383/400 low profile intake options
[Re: dogdays]
#1676803
09/27/14 12:36 AM
09/27/14 12:36 AM
Posts: 4,334 Prospect, PA
BSB67
Prospect, PA
CH4B is for 440s. DP4B is for 383s and 400s R.
Right
[Re: TonyS451]
#1676808
09/28/14 02:59 PM
09/28/14 02:59 PM
Posts: 16,210 Mesa, Arizona
dart4forte
Mesa, Arizona
Hi all - I know there have been tests done, but I'm looking for a low profile intake to bolt onto a 400 engine with stock heads (some porting). I don't want to mess with the kickdown or throttle cable linkage, and not looking to make max power, just make a quick bolt on swap from the factory boat anchor. Any upgrade from stock would be nice. I know the performer intake is out there, and if I recall, there is not much gain over stock other then the weight loss.
The engine also sports a Crane powermax hydraulic ft cam 224/234 @.050, .467/.494 lift, 114 lsa, 750 edelbrock carb and headers, in a 71 D200 truck.
Any info is appreciated. thanks!
I used the Street Denominator with a 850 TQ on my 451. Motor responded really well with that combo
[Re: dart4forte]
#1676809
09/28/14 04:46 PM
09/28/14 04:46 PM
Posts: 6,120 Valencia, España
NachoRT74
Valencia, España
I was on same deal. Simply went with the regular performance intake on my stroked 400 ( 451 wannabe ). Performer is a bit higher than the iron stock one... maybe half an inch. Just needed to trim out some tuff to fit correctly the A/C Compressor.
BUT as mentioned looking forward to Holley Street Dominator or its similar one made by Edelbrock ( which I can't recall its name on this moment ) what is kinda more stockish look... if we can say that somehow
