Re: 383/400 low profile intake options [Re: dogdays] #1676803
09/27/14 12:36 AM
09/27/14 12:36 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
CH4B is for 440s.
DP4B is for 383s and 400s
R.
Right
Re: 383/400 low profile intake options [Re: BSB67] #1676804
09/28/14 07:07 AM
09/28/14 07:07 AM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Tony,
I have a Holley Street Dominator for sale. Nice condition, Bolt holes in good shape, mounting faces doesn't appear to have been machined. If interested email me at ronnman(at)bellsouth(dot)net.
Ron
Re: 383/400 low profile intake options [Re: Ronnman] #1676805
09/28/14 12:28 PM
09/28/14 12:28 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I would just use a performer RPM, they are just over $200 if you shop around and the best compromise between all the designs and work well everywhere.
A 68 charger with a low deck-
M1 / 4500 dominator combo.
M1 / 4150 - 950 Holley
PERF RPM / holley carb combo. All fit with a small drop bas air cleaner.
So far my favorite on my engine, 10.4/1 470 is the eddy rpm with a 1000cfm annular booster holley.
Re: 383/400 low profile intake options [Re: Joshs68] #1676806
09/28/14 12:51 PM
09/28/14 12:51 PM
USA
hudsonhornet7x Offline
USA
Thanks for the information. I take it that was under a stock hood?
Re: 383/400 low profile intake options [Re: Joshs68] #1676807
09/28/14 01:40 PM
09/28/14 01:40 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
I agree the RPM is the best all around and your
71 dodge truck hood will have all the clearance
you need even with a tall air cleaner
Snap your neck, mega G-force launch, is all I want!
Re: 383/400 low profile intake options [Re: TonyS451] #1676808
09/28/14 02:59 PM
09/28/14 02:59 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Hi all - I know there have been tests done, but I'm looking for a low profile intake to bolt onto a 400 engine with stock heads (some porting). I don't want to mess with the kickdown or throttle cable linkage, and not looking to make max power, just make a quick bolt on swap from the factory boat anchor. Any upgrade from stock would be nice. I know the performer intake is out there, and if I recall, there is not much gain over stock other then the weight loss.
The engine also sports a Crane powermax hydraulic ft cam 224/234 @.050, .467/.494 lift, 114 lsa, 750 edelbrock carb and headers, in a 71 D200 truck.
Any info is appreciated. thanks!
I used the Street Denominator with a 850 TQ on my 451. Motor responded really well with that combo
Re: 383/400 low profile intake options [Re: dart4forte] #1676809
09/28/14 04:46 PM
09/28/14 04:46 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I was on same deal. Simply went with the regular performance intake on my stroked 400 ( 451 wannabe ). Performer is a bit higher than the iron stock one... maybe half an inch. Just needed to trim out some tuff to fit correctly the A/C Compressor.
BUT as mentioned looking forward to Holley Street Dominator or its similar one made by Edelbrock ( which I can't recall its name on this moment ) what is kinda more stockish look... if we can say that somehow
Re: 383/400 low profile intake options [Re: NachoRT74] #1676810
09/28/14 04:54 PM
09/28/14 04:54 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Street Master is the one I couldn't recall!
Re: 383/400 low profile intake options [Re: NachoRT74] #1676811
09/28/14 11:16 PM
09/28/14 11:16 PM
Eugene, OR
FuryBoy Offline
FuryBoy  Offline
Eugene, OR
Street master is a fuel economy intake, isn't it? Kinda like an Sp-2p
Re: 383/400 low profile intake options [Re: FuryBoy] #1676812
09/29/14 02:45 AM
09/29/14 02:45 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I just switched from a torker II 440, to an RPM on my W100. 4" filter, no drop base. I did have to massage the center rib for clearance. Also, it's a 79 hood, might be a tad taller.
HUGE drive ability increase with the dual plane. Drop base would probably give all the clearance needed. B series just makes it easier.
Re: 383/400 low profile intake options [Re: dodgeboy11] #1676813
09/29/14 08:40 AM
09/29/14 08:40 AM
SE PA
Yellow Fever Offline
SE PA
Here's mine with a drop base air cleaner, the factory cleaner would work with this drop base but I kinda liked the chrome 383 with the aluminum valve covers.
Re: 383/400 low profile intake options [Re: FuryBoy] #1676814
09/29/14 10:36 AM
09/29/14 10:36 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
dunno but from the distance looks allmost the same to the Street Dominator but with a correct booster vacuum source and EGR locations
