Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS [Re: mopars rule] #167682
12/19/08 09:58 AM
12/19/08 09:58 AM
Connecticut
5126brl No more Offline
Connecticut
I had a sump put in my tank years ago and the welder only had a pair of # 10'S so he put those in.
I can tell you that the fittings get very pricey when you start buying # 10 stuff. Also space become a issue when routing # 10 hose.
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS [Re: chryco] #167683
12/19/08 11:48 AM
12/19/08 11:48 AM
N
NITROUSN Offline
NITROUSN  Offline
N
-12 out of the tank to the pump , -10 to the reg , -8 to the carb .
Thats the way I set them up.
