Re: Front End Recommendations - Stock K [Re: Pale_Roader] #1676344
10/17/14 10:10 PM
10/17/14 10:10 PM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I'm about halfway there with steering box gussets. They're thin [0.063"], also 4130 plate I had around. I think they'll be sufficient.
....I need a TIG.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Front End Recommendations - Stock K [Re: GoodysGotaCuda] #1676345
10/17/14 11:49 PM
10/17/14 11:49 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Awesome! More K-member pics please!
I need to do that as well when I pull out my engine
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Front End Recommendations - Stock K [Re: Pale_Roader] #1676346
10/18/14 11:55 PM
10/18/14 11:55 PM
IN
ahy Offline
ahy  Offline
IN
For the T bars, you need more than .9". What is "right" is application dependent and heavily debated. I like my 1" bars. 1.1" sounds good also and needs high end shocks to control. Budget?
Why would stiffer T-bars need better shocks? I know everything should always have the best shock in the budget, but is there an actual need for a superior shock if the front spring rate is serious?
So far my 70 Challenger's budget is looking like VERY serious T-bars (best available) and not much better than stock range shocks. We cant all afford Bilsteins. I NEED to buy T-bars (mine are 6-cyl), and i'm not buying them twice. I'll upgrade shocks down the road when funds allow.
Really stiff bars without high end shocks may be herky-jerky. Unpleasant ride and compromised handling. The lower end shocks (like my KYB's) cannot effectively control the high spring rate.
Re: Front End Recommendations - Stock K [Re: ahy] #1676347
10/19/14 12:18 AM
10/19/14 12:18 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Shock rates and spring rates need to be matched. KYB's are good for maybe .92" A body bars.
Don't be the exception.
Re: Front End Recommendations - Stock K [Re: Supercuda] #1676348
10/19/14 02:05 AM
10/19/14 02:05 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Correct... the behavior of the system is determined by the dampening ratio, which is a function of spring rate and the shock rate. To maintain the same dynamic response the shock rate has to be increased to match the spring. If you increase the spring without increasing the shock rate the car will tend to be under damped and it will oscillate because the spring is overpowering the shock.
-Michael
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: Front End Recommendations - Stock K [Re: GoodysGotaCuda] #1676349
10/19/14 09:41 AM
10/19/14 09:41 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
I hope you are taking this advice-
You need to turn up the heat[current]!!!. Do not be afraid to sink some heat into those welds. Those are not the nicest welds. I am skeptical that you are wearing the necessary safety equipment - welding respirator, welding hat, safety glasses, welding jacket & gloves - because welding a k frame creates a lot of sparks, smoke and heat. The smoke is toxic.
Weld everything that has a seam even where it was welded before. Esp where the steering box mounts. You missed a spot in one of the pics.
Re: Front End Recommendations - Stock K [Re: ThermoQuad] #1676350
10/19/14 06:21 PM
10/19/14 06:21 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
And I would add, those dimpled holes are best located in the areas of the lowest stress ( ie normally the geometric local plane center) to have the best bang for buck, and that smaller center located dimple doesn't look to be adhering to that theory. But I can't tell if you added it, enlarged it or just dimpled an existing hole.
Re: Front End Recommendations - Stock K [Re: jcc] #1676351
10/19/14 06:29 PM
10/19/14 06:29 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
.... and that smaller center located dimple doesn't look to be adhering to that theory. But I can't tell if you added it, enlarged it or just dimpled an existing hole.
Yep.
