trans problems #1676296
09/23/14 09:50 PM
09/23/14 09:50 PM
moscow mills mo
smracing Offline OP
smracing  Offline OP
moscow mills mo
trans has less than a thousand miles on it 3500 stall it will not up shift until it gets warm after a 45 mile drive I shut the car off sounded like turbine shutting down after motor and cuda is not moving
rebuild again or bad converter
car will not move in drive must put it in low
mild 440 391 gears ect
looking for advise on trans builders in st.louis
Re: trans problems [Re: smracing] #1676297
09/24/14 07:47 PM
09/24/14 07:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Classic symptoms of a failed sprag.
BTW, the CAPS key is on the left and the PERIOD key is down on the bottom. Using them would make your posts easier to read.
Re: trans problems [Re: John_Kunkel] #1676298
09/25/14 12:06 AM
09/25/14 12:06 AM
moscow mills mo
smracing Offline OP
smracing  Offline OP
moscow mills mo
thanks
