Re: 60 ft. time still stinks! [Re: Cab_Burge] #1675880
09/23/14 07:22 PM
09/23/14 07:22 PM
N.Y.
sixpacksteve Offline OP
N.Y.
it has 12.5 flat top ross pistons, 684 bullet roller cam, edelbrock alum max port heads, flowed 375, t&d rockers, indy max intake, holley 1150 carb. 2" hooker fenderwell headers. ultimate redid the conv. to my specs. and i've tested it, flashes at 55k. the track lebanon valley. if i can go fast there it should be fast anywhere.
Hell Hath No Fury Like Mine
Re: 60 ft. time still stinks! [Re: sixpacksteve] #1675881
09/23/14 07:28 PM
09/23/14 07:28 PM
N.Y.
N.Y.
here's a video of previous races, with my friends duster. he has a 9 sec. car his 60 ft. are 1.54 average http://youtu.be/aJgmFzydp7A
Re: 60 ft. time still stinks! [Re: sixpacksteve] #1675882
09/23/14 07:32 PM
09/23/14 07:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Did Lenny at Ultimate agree with the specs you called
out for... whats the peak torque rpm of the engine..
have you videoed any passes to see if its spinning
and whats the rest of the cam specs
Re: 60 ft. time still stinks! [Re: MR_P_BODY] #1675883
09/23/14 07:36 PM
09/23/14 07:36 PM
N.Y.
N.Y.
i gave Lenny a piece of info on the car. i even put john deere fluid in the trans as well! i'll be back with cam specs! i shift @ 7k and go threw the traps @ 7k
Re: 60 ft. time still stinks! [Re: sixpacksteve] #1675884
09/23/14 07:58 PM
09/23/14 07:58 PM
Central New York
bfury Offline
bfury  Offline
Central New York
As we say in ny "not for nothing" but are the front wheels on the ground at the 60? We had that problem.
No Stock
Re: 60 ft. time still stinks! [Re: bfury] #1675885
09/23/14 08:02 PM
09/23/14 08:02 PM
fullmetaljacket Offline
Your cam specs are very important. What's the full cam grind numbers?
Re: 60 ft. time still stinks! [Re: sixpacksteve] #1675886
09/23/14 08:19 PM
09/23/14 08:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A piece of info...all the info they can get only
helps tune it in
Re: 60 ft. time still stinks! [Re: bfury] #1675887
09/23/14 08:29 PM
09/23/14 08:29 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
At that ET, crossing the 60 foot markers with the back tires is about 10-12 hundreds. I have done it enough and compared time slips after a good amount of runs. Car has to be a good bit up in the air that far out for the timers to see the rear tires first.
It's extremely unlikely that is going on with the OP's car.
To the OP the cam specs( lsa, where installed, duration,etc, etc) are important items we need to help you.
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
Best so far, 10.32 1/4
1.41 best 60 foot
6.56 at 104.17
