Re: 60 ft. time still stinks!
[Re: Cab_Burge]
#1675880
09/23/14 07:22 PM
09/23/14 07:22 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
it has 12.5 flat top ross pistons, 684 bullet roller cam, edelbrock alum max port heads, flowed 375, t&d rockers, indy max intake, holley 1150 carb. 2" hooker fenderwell headers. ultimate redid the conv. to my specs. and i've tested it, flashes at 55k. the track lebanon valley. if i can go fast there it should be fast anywhere.
Hell Hath No Fury Like Mine
[Re: sixpacksteve]
#1675881
09/23/14 07:28 PM
09/23/14 07:28 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
here's a video of previous races, with my friends duster. he has a 9 sec. car his 60 ft. are 1.54 average http://youtu.be/aJgmFzydp7A
[Re: sixpacksteve]
#1675882
09/23/14 07:32 PM
09/23/14 07:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Did Lenny at Ultimate agree with the specs you called out for... whats the peak torque rpm of the engine.. have you videoed any passes to see if its spinning and whats the rest of the cam specs
[Re: MR_P_BODY]
#1675883
09/23/14 07:36 PM
09/23/14 07:36 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
i gave Lenny a piece of info on the car. i even put john deere fluid in the trans as well! i'll be back with cam specs! i shift @ 7k and go threw the traps @ 7k
[Re: sixpacksteve]
#1675886
09/23/14 08:19 PM
09/23/14 08:19 PM
MR_P_BODY
A piece of info...all the info they can get only helps tune it in
[Re: bfury]
#1675887
09/23/14 08:29 PM
09/23/14 08:29 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
As we say in ny "not for nothing" but are the front wheels on the ground at the 60? We had that problem.
At that ET, crossing the 60 foot markers with the back tires is about 10-12 hundreds. I have done it enough and compared time slips after a good amount of runs. Car has to be a good bit up in the air that far out for the timers to see the rear tires first. It's extremely unlikely that is going on with the OP's car.
To the OP the cam specs( lsa, where installed, duration,etc, etc) are important items we need to help you.
