A1000 pump Dropping Pressure?
#1675432
09/21/14 10:50 PM
09/21/14 10:50 PM
Posts: 12,421 Taxes & Virus's R-US, NY
Dragula
Car wasn't running right, switched carburators thinking it was the SV1. I found that after a pass with my 4150 that seemed way slow and lean, I found my pressure was down, and so I adjusted it. I knew it was correctly adjusted....Next pass, it was, better, but low again...Adjusted it again, and it dropped again.....
Next day, it was way too high when I fired the car up....Not sure what the heck is with it.
Drained the tank and removed the pump...filter had a bunch a gunk in it...but not enough to cause an issue...Pulled the regulator apart nothing there either...Needs a pump?
Re: A1000 pump Dropping Pressure?
[Re: MR_P_BODY]
#1675434
09/21/14 11:17 PM
09/21/14 11:17 PM
Dragula
Have you checked voltage AT the pump.. if you knew the amp draw you could check that also
In a carburated app, it should be 8-10 amps...I did find the two bolts to the wires slightly loose, but doubt that is the missing 10lbs of pressure. And its already out of the tank....
My biggest regret was running AN08 for this pump install. I wish I had put AN10 thruout like on my pro street truck...This will be expensive if there is a restriction causing the pump to really have an issue.
[Re: Dragula]
#1675435
09/21/14 11:50 PM
09/21/14 11:50 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Double check the location and the flow direction of your pre and post pump filters. DAMHIK. ![](/ubbthreads/images/graemlins/hammer.gif)
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Dragula]
#1675439
09/22/14 05:39 AM
09/22/14 05:39 AM
Challenger 1
Cincinnati, Ohio
New pump on the way...I will call Aeromotive tomorrow if I get the chance...I could sware they said the AN08 would be ok....
You need #10 minimum in the inlet. I bet you there's nothing wrong with your old pump. Don't buy another one, unless you burned up the original by cavitation. Which happens to many pumps.
[Re: pittsburghracer]
#1675445
09/22/14 12:47 PM
09/22/14 12:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Your not using a liquid filled pressure gauge are you? If so you might want to look into draining it.
If you have a filled gauge under the hood as the temp builds it presses back on the gauge guts and will lower the reading.. the higher the temp the lower the filled gauge will read.... if you have one just drain the oil and leave it vented ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1675446
09/22/14 06:41 PM
09/22/14 06:41 PM
Posts: 298 Shelton, Ct.
572_HEMI_Cuda
Shelton, Ct.
that's fine and all but the car is slowing down and if the gauge was working before, Randy needs to look at the pump or pre and post filters.
[Re: 572_HEMI_Cuda]
#1675448
09/22/14 07:05 PM
09/22/14 07:05 PM
MR_P_BODY
Thats true... but he also is saying that the pressure is falling off.. we can assume they are related.. it most likely will be filter or pump or both.. and thats assuming the gauge was working right before ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1675449
09/22/14 07:33 PM
09/22/14 07:33 PM
Dragula
Most of the gunk was the excess thread sealer used on the lid of my custom fuel cell. As I threaded the screws in, the rest must have fell into the cell. I have no post filter after the fuel pump, so anything that gets past the pre filter, 100 micron stainless, it goes all the way up... The gauge is/was liquid, and will be replaced shortly after talking with Aeromotive. I did not know that about the liquid ones.... With that said, I am not sold that it is actually the pump, but it was really lean and this is a known good carb...It went 6.15 last week on the Duster. Its funny because I do not care for the racket the Magna Fuel makes in the Duster nor the bouncy readings on the pressure gauge, but that car runs fine. ![](http://i427.photobucket.com/albums/pp357/cudahalr/70HemiCuda/hemi97863-2.jpg)
[Re: Dragula]
#1675450
09/22/14 10:46 PM
09/22/14 10:46 PM
MR_P_BODY
So this carb was on another engine last week.. what is the weight of the 2 cars and what is the difference in rpm... did you jet it up on this car since you think its lean ![](/ubbthreads/images/graemlins/wave.gif)
