Re: no oil getting to rockers on new build?
[Re: 80fbody]
#1675290
09/22/14 06:36 PM
09/22/14 06:36 PM
Posts: 1,303 Penna
70satelliteguy
Penna
"What type & weight of oil are you running & standard or high volume oil pump" 10-30 weight and a Melling HV. "Yes it will feed the rocker shafts by just cranking engine, but will take more cranking time to get there than that pressure test port that should show pressure quickly. buildanother : I cranked the motor over for about 10 sec and saw 25 lbs. of oil pressure on my gauge. Was that enough time?? Thank you all for all of the ideas I will try and get back to work on it again soon and report back! Mike
[Re: 70satelliteguy]
#1675294
09/23/14 11:12 AM
09/23/14 11:12 AM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
Could a bad oil filter cause low enough pressure that even when cranking the motor I would not see oil at the rockers? Does the oil go thru the filter before or after the oil pump? Thanks mIke
No , and No the oil goes thru the pump first.
Take off the rockers shaft and put a wire down the hole to see if the cam bearing is lined up right.
Not sure if it's been mentioned but I remember someone having this issue and it was the cam not being drilled.
[Re: skicker]
#1675297
09/23/14 01:29 PM
09/23/14 01:29 PM
JohnRR
A gulag near you.
When you do get oil with the drill be prepared to clean up the mess as it will put a lot out and run down over the edge of the head.
Exactly , I just cut the top off a mashed valve cover I have to contain the mess.
[Re: skicker]
#1675298
09/23/14 05:37 PM
09/23/14 05:37 PM
Posts: 1,303 Penna
70satelliteguy
Penna
"Take off the rockers shaft and put a wire down the hole to see if the cam bearing is lined up right" Will try this also. I appreciate all of the reply's. I probably won't get to work on it again for a few day's but will report back what my results are. Mike
#1675299
09/23/14 09:33 PM
09/23/14 09:33 PM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
Drape a piece of saran wrap over the head.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
#1675300
09/24/14 01:48 AM
09/24/14 01:48 AM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Keep in mind that there are two holes in the cam journal. Find one and try the pump. If nothing happens turn the engine more until the wire finds the other end of the hole. One end of the passage needs to line up with the passage to the head, the other end has to be at 6:00 so that oil can make it into the cam. You're probably fine and I would have started the thing up by now. That said, I did help out a friend recently who had a new roller cam with the hole angles off and they never lined up with the holes in the cam bearing and block simultaneously. It took some die grinder work to chamfer the holes until they did line up. Some expensive pushrods and rockers got burned up before the problem was solved.
[Re: Stanton]
#1675302
09/24/14 05:39 PM
09/24/14 05:39 PM
Posts: 6,232 JERSEY
RJS
JERSEY
IF you still have 25 lbs of pressure by the time you poke your head in the car I'd say you have pressure !! The issue seems to be that you can't "see" it at the rockers so that would indicate a simple cam oil hole alignment problem.
If you're trying to prime it by hand I'd take a few minutes and set that gauge in the engine compartment where you can see it.
I had a hell of a time getting my motor to prime. It just wouldn't suck oil up. I had the pump on and off at least 3 times because it couldn't possibly be anything else. It finally primed and I can only figure that the pump was too dry.
I always pack a new pump with Vaseline to help it prime fast. Ron
#1675306
09/25/14 06:05 PM
09/25/14 06:05 PM
Posts: 9,038 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Stealth heads must only have one hole to oil the heads in the stands. The other one is blind about an inch down
Really ?!?!?! That would mean the heads are not interchangeable side-to-side and you got lucky when you installed them !!!
Actually, the block only has oil passages at the #4 cam journal. The "blockage" you encountered is the deck surface.
