Ideas for a stout stock stroke 340 build.
#1673972
09/18/14 11:33 PM
09/18/14 11:33 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
I am thinking about building a 30 over 340 "big" motor to have as a backup to this 318, and perhaps at some point replace it I have access to a nice standard bore 340 with its unturned steel crank, bunch of stuff I wouldn't use,( stock rods and pistons)several stock 340 pans, timing covers, etc for real cheap. I just wondered if say cnc procomp heads, moderate roller cam, zero deck flat top pistons could make 550 horsepower or better? Or any other heads, that are cheap and available If not it wouldn't be a significant enough upgrade to be worth doing. In my old age I am actually back into thinking Dusters/ Darts/ Demons with 340's in them are cool.
Re: Ideas for a stout stock stroke 340 build.
[Re: B3422W5]
#1673978
09/19/14 01:58 AM
09/19/14 01:58 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Don its much easier with a 416... hell you can make over 550 hp and still run 87 octane... spend a bit more now and save on all the fuel costs and make more torque.. I'm at 590 hp on 416 with 87 octane with W-2s
[Re: B3422W5]
#1673979
09/19/14 09:10 AM
09/19/14 09:10 AM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
You need to talk to Bondo Bob. He has a pump gas 422 in his Dart Swinger with CNC Procomp heads. It is a full stock interior street car, and went 10.50's on the motor. He sprayed it last weekend at MMW and went 6.1? in the 1/8. What your looking for can definitely be done!
[Re: B3422W5]
#1673980
09/19/14 06:01 PM
09/19/14 06:01 PM
Posts: 4,457 Washington
madscientist
Washington
A 416, eddy headed hydro roller motor at 11:1 with 1.875 headers and a strip dominator will EASILY do 575 at 6000 rpm's. Turn it 6800 with the correct cam and it will go over 600. It will idle at 1000 rpm's.
A solid tight lash roller will do 675-680.
[Re: madscientist]
#1673981
09/19/14 06:54 PM
09/19/14 06:54 PM
B3422W5
Portage,michigan
Frankly, I have already had 9 sec, 10 sec, and 11 sec small block stroker motors in my old car. No doubt they will make more power. This build will be just stock stroke. Don't mind having less torque. Less torque won't break this 8.75 rear I don't want to replace. And will hook easier with this stock suspension deal I have. I have never had a 340 that will run 10's, and my hope is that a well thought out build will achieve that in the current heap that I have. I am probably hard headed but just want something I haven't already had next time. Be it harder to do or not
[Re: madscientist]
#1673982
09/19/14 06:56 PM
09/19/14 06:56 PM
Posts: 3,421 Toronto
mshred
Toronto
80hp from a solid roller?
[Re: Belvedere2]
#1673984
09/19/14 07:20 PM
09/19/14 07:20 PM
B3422W5
Portage,michigan
I don't think it's impossible just not streetable or inexpensive. My 380 does 550hp but is a 48* W-2 mini stroker that runs on 110. Much easier to follow Mr P's idea on a 416 that runs on 87. You'll be happier in the long run.
I will already have the block and crank, can use shelf diamond pistons and probably like a scat H beam rod. Won't be real expensive at all. Lots of stuff I already have. Don't really care about having to maybe mix 110. It's 6.99 a gallon here, and it's not like I have the time to log a ton of miles on the street. So even if it costs me 300 extra a summer for fuel( unlikely) that isn't enough of a negative to matter to me. Don't think it needs to be radical to run 10's even in a 3400 pound car. Just need good heads.
[Re: B3422W5]
#1673985
09/19/14 07:42 PM
09/19/14 07:42 PM
Posts: 207 People's Republic of Mass.
Belvedere2
Hmmm. True. Do you think W-9s would be feasible? Not sure but they might flow in the 300s with mild cleanup. Course that makes acces. parts more exotic. I'm just not well versed in other heads. I like my W-2s.
[Re: Belvedere2]
#1673987
09/19/14 07:59 PM
09/19/14 07:59 PM
B3422W5
Portage,michigan
Those cnc pro comps like bondo has went high 280's on a reputable bench. He built a 60 over 340 with 4 inch crank at 9.5 compression and has already been 10.57 in his bench seat swinger. I figure his crank is probably 3 tenths better than similar build stock stroke. But I would have well more than 9.5 compression. Think a head like that will sneak into the 10's with stock stroke. Without working up a ton of sweat and be very street able.
[Re: B3422W5]
#1673989
09/19/14 09:16 PM
09/19/14 09:16 PM
madscientist
Washington
I apologize for not reading closer.
Let me say this about what you wrote: not sure on the pro comp heads. Didn't like the BB heads I have done but they are ok. If you spend the time on the intake manifold (most guys skip over this but it is a big deal) and get it correct, and your headers are good 550 is not out of the question. 500 is 1.47 HP/CI so it needs to be properly spec'd. 550 is 1.6 HP/CI. You will have to have you crap wired tight to get there but it is doable.
[Re: madscientist]
#1673990
09/19/14 09:38 PM
09/19/14 09:38 PM
B3422W5
Portage,michigan
Just reread an old Mopar Muscle magazine article from 2003. They took a stock stroke 340, bolted on W9 heads that were pretty much stock( minor work, they went 280@.600) and with a 260@50 roller made 602 horse at 7000rpm I don't know how much better that head is than the procomp cnc I am thinking about, but it can't be much better, if it is at all
