Re: Engine builders, you have my sympathy
[Re: Dunnuck Racing]
#1673917
09/29/14 02:53 PM
09/29/14 02:53 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
This forum used to be a fun, informative place to share information. Now if you give hard earned information out for free a keyboard cowboy will argue with you. What happened? Keith
I hope it changes. I used to find out lot's of good stuff here, and would, like that to come back. I just finished a Predator build that should have cost several thousand less than it did, and that was the reason for the post. A friend on this site was a huge help in every way, along with people like Pete @ Best. Otherwise, it would have cost much more and taken lots longer. I should have named it "Engine Builders, you have my sympathy, except Indy"! Indirectly, I bet I spent over $25,000 with them and when I needed info, they just wanted to tell me what they would sell me. Oh well, lesson learned.
[Re: camastomcat]
#1673918
09/29/14 05:09 PM
09/29/14 05:09 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
I too would like to see it go back to the old way of sharing information. We will tall anyone anything they want to know. All we can do as racers is share our experiences with the parts we have tried over the years. It gets old coming on here and trying to share our experiences only to be belittle by folks who are either to set in their old ways or never get away from a keyboard long enough to race.
We too are working on out Predator deal. I am very happy for Tom and the way it appears things are headed. I wish nothing but the best for him with this deal .We are doing our best to do it right the first time as well. Already had setbacks with that and now it is apart waiting on some parts to be made to make it right. Hopefully we will eventually have something good to report, dyno numbers and all.
[Re: Al_Alguire]
#1673919
09/29/14 05:21 PM
09/29/14 05:21 PM
camastomcat
Salt Lake City
Well Al, at least we know the power can be had. I think from our discussions, yours will be more of a max effort NOS build. That is, unless you changed your mind and went a different direction. Good luck with it, and let me know if I can help.
[Re: camastomcat]
#1673920
09/29/14 05:38 PM
09/29/14 05:38 PM
Al_Alguire
Las Vegas
Only a motor deal for now..If it cannot hang then it will become a nitrous deal next time with less stroke. Still think new can make some decent power but not 2.2hp per cube is within reach this time with the parts I have and the bleeding needs to stop at some point this go around.
[Re: madscientist]
#1673922
09/30/14 03:28 AM
09/30/14 03:28 AM
Al_Alguire
Las Vegas
Less...Don't ever really see these heads going much over that honestly.
4.506 4.75 7.100 And as much as it takes to get what we want. I aint afraid of no RPM. but realistically it will likely peak around 7800ish.
The bore will keep it from making what I want, just to small but it is a Mopar whats a guy to do. Other than go back to the 99 stuff I was running. Not the most reliable way to make power. The heads were originally Indy 460 Predator heads like Tom has. But they are getting massaged by a very smart guy who will undoubtedly find something more in them. We will post up all the results once we get there. We are waiting on the heads to return and Jesel to make some bushings right now. Let me just say as of right now it has not been very pretty.
[Re: Al_Alguire]
#1673924
09/30/14 08:00 PM
09/30/14 08:00 PM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
I don't think this place is much different than other automotive/racing forums. There is usually more than one way to reach performance goals, it only seems to get rough when there is a disagreement on how to accomplish that.
[Re: madscientist]
#1673926
10/01/14 03:45 AM
10/01/14 03:45 AM
Al_Alguire
Las Vegas
The 99 was just a very maintenance heavy deal. Especially for a TS car IMO. Plus I tend to have to race by myself on occasion and no way that is gonna happen with the 99.
It made real good power even backed down from it's pro stock form, it was right at 2.7hp per cube. Honestly if it were simpler to get more cubes is a killer set up. maybe one day I will revisit it but for now wanted to move on. Had a good run with it and won some races and finished second in heads up class with it by 2 points so we feel we represented Mopar well.
As for the Predator deal the heads are in very competent hands rest assured. If there is anything to be had on top of the Indy CNC work, and there is, it will be found. Just not much we can do about that puny little bore for now.
