Re: Holley Blue pumps and regulators?
[Re: Thumperdart]
#1672016
09/17/14 06:48 PM
09/17/14 06:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
There is NOTHING MAGIC about a regulator... it has a hole and a spring to let the set pressure by.. I dont care for the NON return style reg due to fuel pressure fluctuation and I run a return style(I have for 20 years now).. yes at one time I did run the cheapo holley reg but then I started working in the fuel lab and seen the benefits of the return style systems and have been that way since ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1672017
09/17/14 07:32 PM
09/17/14 07:32 PM
Posts: 4,293 Morrow, OH
markz528
Morrow, OH
Make sure the rubber diaphragm is still soft and pliable and does not have holes! They dry out and that causes problems.
[Re: Chris2581]
#1672020
09/17/14 08:56 PM
09/17/14 08:56 PM
Posts: 5,992 Anoka County, MN
Leigh
Anoka County, MN
Jenkins ran those "cheap" regulators too! I've had nothing but a Holley blue pump on my car since 1981.Not the original pump,as I'm on my 3rd one,but I know I could rebuild the other 2 and they would work just as well.
Not anymore, the lower hsg was discontinued several years ago.
[Re: Thumperdart]
#1672021
09/17/14 08:57 PM
09/17/14 08:57 PM
MR_P_BODY
You need .5 pounds of fuel for 1 HP per hour... its just math... but all of use run WAY more than needed when it comes to pumps.. BUT hopefully its the last one you ever buy... I have tended to buy 2 cheaper pumps as in the blue Holleys and run them in parallel for the volume(pounds per hour) and it ends up cheaper than 1 big pump.. by a lot ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Thumperdart]
#1672022
09/17/14 09:16 PM
09/17/14 09:16 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Again, my car fell on it`s face past the 1/8th w/a black Holley and the Aeromotive.............installed the 300 Magnafuel and had to re-tune the carb and went solid 9`s. And my car`s not that bad azz............
Ummmm, if you "had to retune the carb", how do you KNOW the pump/reg was causing your problems?
I once tried a billet cement mixer pump and high $$ reg on a low 10 second combo, replacing JUST the 10 year old Blue pump and reg. Adjusted the PSI to be the same, and ran it. Weather station was identical to the weekend before and said I should go 10.30's based on my data. (With the old Holley stuff).
Guess what??? 10.30's at the same speed with the new (thankfully borrowed) high $$ "junk".
It LOOKED trick though...
[Re: cudadoug]
#1672023
09/17/14 09:39 PM
09/17/14 09:39 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
Gotta agree with ya. My old 9.80's car( 3350 weight) ran a Holley black and Holley large port regulator for years. Ultra consistent car, saw about 7500 at the stripe every pass. I caved in to peer pressure and went hog wild witha return style way bigger pump/ lines,etc, etc..... And saw zero difference after throwing a grand at a nonexistent problem. My new car is much slower, but I run a pump similar to a black on it through the stock tank sock, 5/16 line and small Holley regulator. It pulls hard on the back half of the track for what it is, zero nosing over. I have no concerns it's leaning out. Just my ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: B3422W5]
#1672025
09/17/14 09:46 PM
09/17/14 09:46 PM
Thumperdart
State of confusion
Small motor, small demands try that w/a stout big block and report back with us. Also do you have a wideband? Install one then you`ll see the fuel curve w/your own eyes and can verify not assume..........My car pulled like a beast, went to chassis dyno and was approaching dangerously lean 16.1 numbers.............. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Thumperdart]
#1672028
09/17/14 10:02 PM
09/17/14 10:02 PM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
I ran a black billet Holley pump and a small port Holley regulator on my Dart, at the 1/8 mile my pressure would be around 2 pounds. I put a new Magnafuel Quickstar 275 and a Holley big port regulator and my fuel pressure stays near 6 pounds now. I don't know if the regulator or the pump fixed my issue, but one of them did.
Total bs.NO WAY.............
Hard to believe I know .......... ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: cudadoug]
#1672029
09/17/14 10:22 PM
09/17/14 10:22 PM
Posts: 1,628 anywhere@ anytime
actionange
anywhere@ anytime
I have REALLY hurt some guys feelings about their fuel regulators on my flow bench...........LOL!!.....Those "cheap" Holley regulators are the most repeatable and consistent regulator you can buy. The only drawback they have is the inner flow path diameter. But it requires BIG power to need more fuel than they can deliver and they are more than enough reg for 99% of guys
Monte
THIRTY YEARS AGO, the first 500" P/S cars were in the 7's, right? Holley Blue pumps and those cheap dead head regulators were the real deal.
So I cannot help but when a guy tells me that his motor NEEDS that $500 billet cement mixer pump and $200 regulator on his 9.80/135 mph car, "Cause it was too lean with the Holley stuff". YEPPERS, just had a Mopar racer tell me that a few weeks ago when I asked about his recent fuel system "upgrade". Oh, and he's really puzzled how there isn't any gain on the time slip...
I totally agree with both of these statements. I used a Holley Blue and regulator with no issues. 10.0@ 136 doesn't miss a beat. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Thumperdart]
#1672030
09/17/14 10:27 PM
09/17/14 10:27 PM
B3422W5
Portage,michigan
What do you mean, small motor small demands? Car ran the same numbers yours does and was 150 pounds heavier ![](/ubbthreads/images/graemlins/confused.gif)
[Re: Thumperdart]
#1672032
09/17/14 10:45 PM
09/17/14 10:45 PM
B3422W5
Portage,michigan
Trust me, that 9.79 was my first full boogie pass and had several issues w/the carb and suspension so a 9.59-9.64 is comin soon. And kudos, your car hauled azz..............
Quit being so nice. You make it hard to pick on ya ![](/ubbthreads/images/graemlins/beer.gif)
