Re: Best years for diesel Ram?
[Re: dusturbd340W5]
#1671158
09/22/14 01:34 PM
09/22/14 01:34 PM
Posts: 1,121 State, country, etc.
gss
Looked at an '06 2500 over the weekend. 120,000 miles but mint in and out for $23,000. Thought it was odd that it had black fender flares on a dark red metallic body. Hmmm, several other used Rams on the lot had the same fender flares. Salesman says Oh no, we didn't put those on, no way we did that. I pulled up the online pictures and there are no flares, just a big rust hole above the rear wheel. So, it seems to be S.O.P. to cover the rust with flares and claim the truck is rust-free. Oh well, there is a 2004 for $19000 that I will check out this weekend.
[Re: gss]
#1671159
09/22/14 09:42 PM
09/22/14 09:42 PM
Posts: 2,484 Minneapolis, MN
hemi70se
Minneapolis, MN
If you are looking for a 3rd gen Ram I would buy a late 07 or 08 with the 6.7 motor and get a MEGA cab if you can afford it. Nothing wrong with the earlier 5.9 trucks but I don't understand why anyone would want to live with a 4 SPEED automatic when you can have a 6 speed automatic. 5.9s generally have a RE48 trans, have you seen one? they are puny, look like a 727 and your going to run 600lbs of torque through it? I'd much rather have the 68RFE from behind a 6.7 Cummins, it's beefier, you can also switch to a lower gear with the flick of a switch on the column. Now if you remove the DPF, EGR, and CAT you can also get just as good of mpg as any 5.9. I've had plenty of 6.7's that get 21-22MPG on the hiway. Looking at 04-05s doesn't even give you an option for a mega cab. Then you are looking at 06-08 for a mega. 2006 5.9 mega's are selling for a premium now because of all the buyers who think they are the only ones that get 20+ MPG. Oh, and 6.7 trucks all come with a factory exhaust brake which is cool as heck.
[Re: hemi70se]
#1671160
09/23/14 01:15 AM
09/23/14 01:15 AM
gss
I don't want a mega cab, in fact if they still made a quad cab, I would buy new. I need to plow my office parking lots in the winter and in the summer I will be using it for trips to the strip and cabin. I need to be able to maneuver around some obstacles in the parking lots so I don't want to go too big. One of the above posts said the 2007+ Rams don't have the same rust problems as the earlier ones so I will expand my search to include the 2007-08. Thanks
[Re: DPelletier]
#1671164
09/23/14 07:45 PM
09/23/14 07:45 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
- 1998.5 12V Quad cab: only year of the quad cab with the bulletproof 12V using the 215hp pump. These trucks had issues with steering boxes and rear brakes.
Wouldn't a 98.5 be a 24v? My friends has a 98.5 sport quad cab, it's a 24v.
Anyways...
As much as I like my 01, it doesn't ride anywhere as nice as the newer ones in my experiences. If I parted with mine I would get an 03-06 6 speed... another friend had an 04 6 sp, I wish I had the $ to buy it when he sold it.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: hemi70se]
#1671165
09/24/14 12:45 AM
09/24/14 12:45 AM
gss
All the 3rd Gen's have the same rust problem over the rear wheel wells because of the support design. If you can afford newer that is the way I would go. The 4th gen CREW cab back seat has way more room than a 03-08 quad cab. If you get a short box the wheelbase would still make it easy enough to maneuver as a plow truck. I just bought a 12 Mega cab Laramie so I will be selling my 2010 Crew Shortbox Laramie 4x4 diesel, only has 23k on it and gets 21MPG.
Sounds like a nice truck. A 2008 is almost a foot shorter than a 2010 I believe. That would let me park it in the third stall of my attached garage so I wouldn't have to keep it in my shop building. Even a 3rd gen would be tight.
