Re: V. Gaines Crashes and Walks Away
[Re: Dabee]
#1670913
09/15/14 02:34 AM
09/15/14 02:34 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Didn't Shane Gray roll his car in the same lane and same place there a couple years ago? I agree they need to resurface that track.
If it truly is toooo smooth to have the rubber adhere to it then grinding the surface would work ![](/ubbthreads/images/graemlins/wave.gif)
[Re: McCandlessboy]
#1670919
09/15/14 12:00 PM
09/15/14 12:00 PM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
Track is notorious as being poorly prepped for 'wingless' high powered door cars (Ask Hemi Fred or Bob Reed....and that was what? Several years back? It's going to be interesting...Friday there was easily LESS than Half of the normal crowd there, in fact if you took all the people on each side and made them sit next to eachother there wouldn't have been enough butts to fill 3 sections of bleachers (Ex: Sections A though C). To me (and a lot of people) If you take the 'under the lights' night session away from a Friday, you kill much (if not most) of the incentive to even go... That being the case, I'm willing to bet that Mr. Bruton is not going to dump a bunch more $$$ into resurfacing...not with all the problems he's already having filling NASCRAP seats... ![](/ubbthreads/images/graemlins/Twocents.gif) I predict Speedway MotorSports (Bruton's company) will be looking (if not already in the works....which knowing Bruton it is) to divest themselves of the NHRA fairly quick, not enough players with deep enough pockets to refill the hole that's going to make. Track seems great for either sub 6 second cars with wings or slower bracket cars, as for Pro Stock....maybe they need some type of Z axis yaw sensor that limits/kills power once they start skating above say 100 mph, no downforce of course also means your brakes aren't going to do very much for you...easy fix and the technology is already there...but of course that also means it could be manipulated to work as a traction control device. As you can see (evident how the cars can invert and stay more-or-less on path) that a Pro Stock car is about as aerodynamic upside down as it is right side up....just like a bullet. So the tires aren't doing much gripping for the brakes to do very much on the big end without the chute deployed. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: slantzilla]
#1670921
09/15/14 12:56 PM
09/15/14 12:56 PM
Posts: 4,715 Wichita
GY3
Wichita
Some were saying they only prep to 1000 ft. for the TF classes. If they prep past that the fuelers chunk the tires. If that's the case and they have 4 lanes, why not prep 2 for PS and Bike classes and the other 2 for the Fuelers?! ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Cudajon]
#1670924
09/15/14 07:49 PM
09/15/14 07:49 PM
Posts: 2,525 Louisville, KY
E-Ticket
Louisville, KY
All this talk of wings wouldn't have helped AJ. he went loose before the 330. Track sux. Fix it.
EXACTLY!!!
[Re: Cudajon]
#1670926
09/16/14 01:21 AM
09/16/14 01:21 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Jason Line went 6.53 at 210 that round..........there is a such thing as proper setup for the track conditions
[Re: MR_P_BODY]
#1670930
09/16/14 03:01 AM
09/16/14 03:01 AM
Monte_Smith
North Alabama
If they did mandate a (as a number) a 1" wicker bill to ALL the pro stocks it could correct this issue
YEP............This has been an ongoing thing for years. The PS guys continually run their stuff on the ragged edge as far as downforce and when the track is not as good as THEY think it should be, it's junk. You know, if I was in the lanes and saw a couple cars getting loose at the top, I think I might raise the wickerbill a little......but that's just me
Monte
[Re: Monte_Smith]
#1670931
09/16/14 12:22 PM
09/16/14 12:22 PM
Streetwize
Weddington, N.C.
I ran at Zmax a few years back, all passes were in Lane 2 and it is the smoothest track I have personally been down. But rubber adhesion and water seepage are 2 issues I've been told are issues at this track, that said NC is an area of the country where we have fairly extreme temperature and humidity changes. particularly in the late winter, I've seen 50 degree swings back and forth and back again within one week (Low 30's to low 80 and back to the 30's) over the course of 3 weeks spans as recently as last March.
Cars ran pretty well at the 4 wide back in April....Wonder if this is not mostly track prep. The track pretty much sits dormant between events, they need to run more T&T's during the year but they won't because of the High Overheads of opening a 4 lane track....Someone told me it cost's $6000 per hour to staff and light the track for a T&T, so without sponsor subsidies it's just not going to happen.
[Re: Streetwize]
#1670932
09/17/14 01:54 AM
09/17/14 01:54 AM
Monte_Smith
North Alabama
Zmax is a National Event track, plain and simple. The weekly, or whenever else they run prep is irrelevant, because it simply doesn't matter to them. That track doesn't NEED to be open and racing to support itself. Bruton sure doesn't need the money. Even if they DID run on a weekly basis, NHRA comes in and completely scrapes a track to bare surface and re-preps for a national event anyway. The "traction twins" told me once that was the nicest surface they had ever prepped ![](/ubbthreads/images/graemlins/shruggy.gif) Monte
