http://www.wallaceracing.com/plug-reading-lm.html
Thanks for reminding me of those pictures
Put the 7's in and dropped boost for pump gas and went to a car show today in Lido Beach.It was 35 miles round trip.
Did not have a chance to pull any plugs,curious to see if they cleaned up in the cruze mode
If you`re trying to clean up the cruise mode you most certainly need the idle circuit nice and clean which carries over to the cruise. Idle bleeds, t-slot position, ifr sizes timing etc. I just turned a mush pot carb into a clean idling and running beast w/more to come and my friends first 9-second slip to follow. Most focus on wot mph and forget that more time is spent at idle and cruising weather track or street................
