Re: Spark plug heat range??
[Re: hemi-itis]
#1669662
09/14/14 04:52 PM
09/14/14 04:52 PM
Posts: 4,213 New York
polyspheric
New York
Actually, if the plug is too cold you have an easier time firing it, if by "firing" you mean "the current finds a path to ground". Instead of jumping the electrode gap (creating a spark between the center post to the side electrode and then to the plug body), the electrical charge follows the conductive fouling material down the porcelain to the plug body and completes the circuit without making a spark.
Boffin Emeritus
[Re: hemi-itis]
#1669665
09/14/14 10:31 PM
09/14/14 10:31 PM
Posts: 97 Florida
johnmilner
Mr P,would that also cause a misfire at higher RPM??
the middle plug looks good.
[Re: johnmilner]
#1669666
09/15/14 12:51 AM
09/15/14 12:51 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I forgot to say that static is 8:1 on gasoline ![](/ubbthreads/images/graemlins/coool.gif)
Look at the strap on that plug,the line is just above threads,too much timing,but the inside of the plug looks good.I have to put a few passes on a set of 9's and see how they look.
[Re: hemi-itis]
#1669668
09/15/14 01:37 AM
09/15/14 01:37 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I dont think thats true... since you have very little time on them the color on the strap is up on the flat but its hard to see being new plugs... your not fat based on those pics but you say cruise is... I've never played with that single bbl carb but if it tunes like any carb then you need to lean down the idle jets and fatten up the high speed to compensate for the less idle ![](/ubbthreads/images/graemlins/wave.gif)
[Re: hemi-itis]
#1669670
09/15/14 02:21 AM
09/15/14 02:21 AM
MR_P_BODY
Are the idle air bleed only for idle or do they effect the tip in also??
They change the amount of air being sucked in through them... if they are small it pulls more fuel from the jet... so it can change tip in.... do those have all the same stuff as a regular carb like pump cams and squirters... can be the squirters to small or when they start... does it idle nice.. because a lean idle can also cause that ![](/ubbthreads/images/graemlins/wave.gif)
[Re: hemi-itis]
#1669677
09/16/14 01:20 AM
09/16/14 01:20 AM
Posts: 2,177 ill
dennismopar73
ill
Also...try 7's
Think they would be too cold
7`s are hotter than 8`s in NGK`s............didn`t notice if you had a wideband or not but tuning idle, cruise and wfo can be a bear w/out one............doable yes but a bear otherwise especially if you have an off idle stumble and don`t know if it`s rich or lean.
I went the wrong WAY I put in 9's instead of 7's
Lower the number hotter the plug guys Opposite of champions n autolites
[Re: Cab_Burge]
#1669678
09/16/14 01:27 AM
09/16/14 01:27 AM
hemi-itis
10 lbs with stockish iron heads and a siamesed iron block. It was breaking up over 6k RPM until I increased the timing to 35* and it woke right up.I had started taking timing out over 5500 RPM and it did not like that.Best pull was 9.907 @140 MPH with 35* and NGK 8's.Patrick advised me to go one step hotter and I went the wrong way ![](/ubbthreads/images/graemlins/blush.gif) I'll test again with 7's and see what happens before any carb changes.
