Page 2 of 4 1 2 3 4
Re: Spark plug heat range?? [Re: hemi-itis] #1669661
09/14/14 04:30 PM
09/14/14 04:30 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
A couple things you can try,bigger air bleed for main jeting,lower fuel psi and cruise to check result,main jetting.
Re: Spark plug heat range?? [Re: hemi-itis] #1669662
09/14/14 04:52 PM
09/14/14 04:52 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Actually, if the plug is too cold you have an easier time firing it, if by "firing" you mean "the current finds a path to ground".
Instead of jumping the electrode gap (creating a spark between the center post to the side electrode and then to the plug body), the electrical charge follows the conductive fouling material down the porcelain to the plug body and completes the circuit without making a spark.
Boffin Emeritus
Re: Spark plug heat range?? [Re: polyspheric] #1669663
09/14/14 05:22 PM
09/14/14 05:22 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
The path of least resistance.
Re: Spark plug heat range?? [Re: polyspheric] #1669664
09/14/14 07:29 PM
09/14/14 07:29 PM
Great Neck,LI,new york
hemi-itis Offline OP
Would there be any type of "witness" trail??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Spark plug heat range?? [Re: hemi-itis] #1669665
09/14/14 10:31 PM
09/14/14 10:31 PM
johnmilner Offline
johnmilner  Offline
Mr P,would that also cause a misfire at higher RPM??
the middle plug looks good.
Re: Spark plug heat range?? [Re: johnmilner] #1669666
09/15/14 12:51 AM
09/15/14 12:51 AM
I forgot to say that static is 8:1 on gasoline
Look at the strap on that plug,the line is just above threads,too much timing,but the inside of the plug looks good.I have to put a few passes on a set of 9's and see how they look.
Re: Spark plug heat range?? [Re: bwhackd34] #1669667
09/15/14 01:01 AM
09/15/14 01:01 AM
Also...try 7's
Think they would be too cold
Re: Spark plug heat range?? [Re: hemi-itis] #1669668
09/15/14 01:37 AM
09/15/14 01:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont think thats true... since you have very little
time on them the color on the strap is up on the flat
but its hard to see being new plugs... your not fat
based on those pics but you say cruise is... I've
never played with that single bbl carb but if it
tunes like any carb then you need to lean down the
idle jets and fatten up the high speed to compensate
for the less idle
Re: Spark plug heat range?? [Re: MR_P_BODY] #1669669
09/15/14 02:06 AM
09/15/14 02:06 AM
Are the idle air bleed only for idle or do they effect the tip in also??
Re: Spark plug heat range?? [Re: hemi-itis] #1669670
09/15/14 02:21 AM
09/15/14 02:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
They change the amount of air being sucked in through
them... if they are small it pulls more fuel from
the jet... so it can change tip in.... do those have
all the same stuff as a regular carb like pump cams
and squirters... can be the squirters to small or when
they start... does it idle nice.. because a lean idle
can also cause that
Re: Spark plug heat range?? [Re: MR_P_BODY] #1669671
09/15/14 01:21 PM
09/15/14 01:21 PM
can also cause that
Yes,they have pump cams & shooters. I had gone to a smaller idle air to try and correct an intermittent stumble on cruze mode tip in.
Re: Spark plug heat range?? [Re: hemi-itis] #1669672
09/15/14 01:45 PM
09/15/14 01:45 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Also...try 7's
7`s are hotter than 8`s in NGK`s............didn`t notice if you had a wideband or not but tuning idle, cruise and wfo can be a bear w/out one............doable yes but a bear otherwise especially if you have an off idle stumble and don`t know if it`s rich or lean.
Re: Spark plug heat range?? [Re: Thumperdart] #1669673
09/15/14 01:56 PM
09/15/14 01:56 PM
Also...try 7's
I went the wrong WAY I put in 9's instead of 7's
Re: Spark plug heat range?? [Re: hemi-itis] #1669674
09/15/14 01:58 PM
09/15/14 01:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No biggie............a 9 might be real good for a blown application.
Re: Spark plug heat range?? [Re: Thumperdart] #1669675
09/15/14 11:57 PM
09/15/14 11:57 PM
I ordered a set of 7's,will have them tomorrow
Re: Spark plug heat range?? [Re: hemi-itis] #1669676
09/16/14 01:17 AM
09/16/14 01:17 AM
How much boost? The last blown(14.71 with two blower 1150 Dominator carbs) iron block aluminum headed 426 Hemi I dyno tested liked 33 degrees total timing with 7.0 lbs of boost on CA pump gas, it didn't like 25 degrees to start with with 12 lbs of boost with C16 race gas We went from 12% under drive with the 7 lbs at 7300 RPM, I reversed the pulleys which gave us 13% overdrive and ended up reaching peak HP at 6500 RPM on the race gas. I tried advancing the timing to 27 degrees which was the wrong way to go I should have probally started at 20 or 22 degrees with the O.D. tune up and went up, OH WELL, thats called getting hands on experiece
Re: Spark plug heat range?? [Re: hemi-itis] #1669677
09/16/14 01:20 AM
09/16/14 01:20 AM
ill
dennismopar73 Offline
ill
Also...try 7's
Lower the number hotter the plug guys
Opposite of champions n autolites
Re: Spark plug heat range?? [Re: Cab_Burge] #1669678
09/16/14 01:27 AM
09/16/14 01:27 AM
10 lbs with stockish iron heads and a siamesed iron block.
It was breaking up over 6k RPM until I increased the timing to 35* and it woke right up.I had started taking timing out over 5500 RPM and it did not like that.Best pull was 9.907 @140 MPH with 35* and NGK 8's.Patrick advised me to go one step hotter and I went the wrong way
I'll test again with 7's and see what happens before any carb changes.
Re: Spark plug heat range?? [Re: dennismopar73] #1669679
09/16/14 01:31 AM
09/16/14 01:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I sure wish ALL of the plug companies would standardize
that... make them all the same way.. I dont care if
its lower the number the colder(which in my thinking
is the right way) but do them all the same... I mess
up with them also except the champions and autolites
Re: Spark plug heat range?? [Re: Cab_Burge] #1669680
09/16/14 01:31 AM
09/16/14 01:31 AM
Iron heads,iron block best pass @ 10lbs was 9.907 @140 mph at 35*.
Page 2 of 4 1 2 3 4
