Page 1 of 4 1 2 3 4
muriatic acid bath! #1668707
09/07/14 11:15 PM
09/07/14 11:15 PM
Tacoma, Washington USA
Adam71Charger Offline OP
After watching Breaking Bad I got an idea. For years I've been cleaning parts like control arms, frames, brackets etc etc with brake cleaner and lacquer thinner, then using a wire brush and wire wheel on an angle grinder to get the remaining rust off. Today, I experimented and put a couple gallons of muriatic acid (from local hardware store) in a plastic 55 gallon drum. I pulled the control arms off my girlfriends nova earlier, and they were caked in grime, oil, dirt and rust. I put them in the drum. They started sizzlin. The fumes were intense so I got a respirator. After 10 minutes, I pulled them out and they were bare bright metal were they had been dipped. Im going to get more and completely submerse them. I cant believe how great it worked.
Is this common knowledge? Does anyone else do this or a similar technique? I had never heard of doing this before. I know that you can get your car acid dipped, but I didnt know there was similar chemical available for over the counter purchase.
It's saved me a lot of time cleaning and grinding.
Re: muriatic acid bath! [Re: Adam71Charger] #1668708
09/07/14 11:22 PM
09/07/14 11:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
A bit of advice, do not put a nut and bolt threaded together in the bath and let it sit over night. You will have no threads left, BTDT. Happened to a set of shock plates I had.
Don't be the exception.
Re: muriatic acid bath! [Re: Adam71Charger] #1668709
09/07/14 11:30 PM
09/07/14 11:30 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I just put my e-body frame rail in my bath, i make forms to fit, been doing this for many years. I mix one gallon acid with 4 gal. vinegar and 4 gal. water. Cheaper this way but takes a little longer. Make sure you use a neutralizer to keep fron rusting back fast.
Re: muriatic acid bath! [Re: cudaman1969] #1668710
09/07/14 11:51 PM
09/07/14 11:51 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
You don't have to use it straight. You can dilute it with water. I bought a cheap plastic tub and have four gallons of it to derust bigger parts. I only bought two gallons and added two gallons of water.
Neutralize it with baking soda water. Dipping the parts in EvapoRust after they are clean will keep them from flash rusting. Don't dip aluminum in the acid. It won't be there when you go to remove it.
Re: muriatic acid bath! [Re: burdar] #1668711
09/08/14 12:25 AM
09/08/14 12:25 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Don't buy the stronger 31.45% solution of Muratic Acid (31.45% Hydrochloric Acid) and mess with it straight. I just went through that ordeal. It's nasty and chokes you out just pouring it out of the bottle.
Get the 15% "low odor" stuff.
It does flash rust uber fast. I dunked it in straight water immediately and directly to neutralize it. While gagging from momentarily opening and closing the ice chest with 3 gallons of 30% Muratic Acid.
After dunking it while still wet I sprayed rust Justice Brother Chain Lube oil (thicker consistency with rust preventative). Kept spraying it to displace the water.
Day later I rubbed off the excess oil.
The manifold on top I just brushed on straight 30% muratic acid with a steel brush and washed with water.
IMHO, I have seen NOS manifolds look like both of them. One on top if the packing oil has evaporated/worn off of it.
BTW these were very nice So Cal manifolds that were recently on a car. No pitting to start with. The heat riser weight was not submerged in the solution as it was just above the Muriatic Acid level.
Re: muriatic acid bath! [Re: burdar] #1668712
09/08/14 12:57 AM
09/08/14 12:57 AM
You guys are right it flash rusted within 60 seconds of washing the acid off with plain water. When you say 'neutralize it' do you mean adding baking soda or vinegar to the acid bath itself? Or do you mean have another bath of neutralizer/water ready to dip the part in after the acid bath?
I am hesitant to spray/coat anything oil-based on the freshly dipped parts, because I want to paint them.
Re: muriatic acid bath! [Re: cudaman1969] #1668713
09/08/14 01:00 AM
09/08/14 01:00 AM
Do you mean your bathroom Bath-tub?
Re: muriatic acid bath! [Re: Adam71Charger] #1668714
09/08/14 01:06 AM
09/08/14 01:06 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Vinegar is acetic acid, I don't think it'll neutralize muriatic. Baking soda will.
Re: muriatic acid bath! [Re: Supercuda] #1668715
09/08/14 07:15 AM
09/08/14 07:15 AM
IN
ahy Offline
ahy  Offline
IN
One thing to watch out for (in addition to safety!) is "hydrogen embitttlement". The acid leaves hydrogen in the metal which reduces strength, especially with repeated cyclic loading. Baking the part afterwards can get the hydrogen out... which is what a good plating house will do.
Slower methods like de-greaser, pressure wash, wire wheel do not introduce hydrogen. Hot tank is good for suspension parts also. Hot tank followed by abrasive blast is really nice.
Re: muriatic acid bath! [Re: Adam71Charger] #1668716
09/08/14 09:16 AM
09/08/14 09:16 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
I've been playing around with diluted Citric acid recently which works very nicely aswell to derust metals.
If you're not in a hurry it will derust rusty metal in a couple of days.
Re: muriatic acid bath! [Re: Adam71Charger] #1668717
09/08/14 10:22 AM
09/08/14 10:22 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Say no to acid, there are better ways but takes more costly equipment but is more environmentally friendly to do it.imo.
Acid makes it too hard to refinish before rust reappears and can harm some parts if not all of them, your forced to rinse with water and hope you get it all neutralized and your trying to get rust off in some cases and your using water to get rust off during the rinse??
Not for me...
Re: muriatic acid bath! [Re: BigBlockMopar] #1668718
09/08/14 10:48 AM
09/08/14 10:48 AM
Andrewh Online content
Andrewh  Online Content
the real issue is, how do you get rid of the stuff when you are done?
Re: muriatic acid bath! [Re: Andrewh] #1668719
09/08/14 11:41 AM
09/08/14 11:41 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
What came from the Earth, returns to the Earth...
Re: muriatic acid bath! [Re: Commando1] #1668720
09/08/14 11:50 AM
09/08/14 11:50 AM
Cincinnati, Ohio
Cincinnati, Ohio
We used to get some kind of acid in a 55 gallon drum and soak aluminum bbq grill half's in them to restore the grill. It was a freaken mess and we spent some big bucks to get rid of the half full drum of acid and slug when we gave up on the acid.
A steam pressure washer is the best tool for restorations of anything. The most environmentally friendly, safest solution for the operator and the part.
Re: muriatic acid bath! [Re: Commando1] #1668721
09/08/14 12:01 PM
09/08/14 12:01 PM
Cincinnati, Ohio
Cincinnati, Ohio
Acid does not come from the earth, it is a chemical and man made, unlike petroleum is what your thinking.
Re: muriatic acid bath! [Re: Challenger 1] #1668722
09/08/14 12:58 PM
09/08/14 12:58 PM
The Netherlands
The Netherlands
Citric acid, for that matter, is found in fruits and sugars.
Re: muriatic acid bath! [Re: BigBlockMopar] #1668723
09/08/14 01:02 PM
09/08/14 01:02 PM
Cincinnati, Ohio
Cincinnati, Ohio
What kind of fruit is muriatic acid found in?
Re: muriatic acid bath! [Re: Challenger 1] #1668724
09/08/14 01:13 PM
09/08/14 01:13 PM
What kind of fruit is muriatic acid found it?
It comes from the Detroit Mulberry Tree
Re: muriatic acid bath! [Re: Challenger 1] #1668725
09/08/14 01:15 PM
09/08/14 01:15 PM
dogdays Offline
dogdays  Offline
Elton John. Seriously.
Muriatic acid is another name for hydrochloric acid, and it is the acid that's in your stomach. It's one of the reasons that we need salt. The chloride ion that occurs when NaCl is dissolved in water is what the body uses to make the acid.
R.
Re: muriatic acid bath! [Re: ahy] #1668726
09/08/14 01:15 PM
09/08/14 01:15 PM
Good point.. I will bake the parts too
Page 1 of 4 1 2 3 4
