Re: Radiator Coolant Recovery Tank for the real cars!
[Re: Pacnorthcuda]
#1668659
09/10/14 08:35 PM
09/10/14 08:35 PM
Posts: 1,715 central il.
second 70
central il.
Mike I use the wiper tank for my overflow on my cuda. Just hook hose to the bottom of tank and then you MUST drill a hole in the top rear of the tank to keep it from air locking. Works great and no one even knows it's being used this way. In 5 years use it has never had any problems. And yes that cap will work. Mike
I also converted the washer bottle on a 70 'Cuda to a recovery system and it works great. A breather hole is not required as the stock flip caps are incapable of holding a vacuum.
Yeah that's what I thought until I installed it without one and it air locked the radiator. Added hole and all was good.
