Re: Radiator Coolant Recovery Tank for the real cars!
[Re: mikemee1331]
#1668643
09/07/14 09:53 PM
09/07/14 09:53 PM
Challenger 1
Cincinnati, Ohio
pre-71 B bodies ! what if anything (aside from the chrome tube thingy from Summit) are people using?? I would really like to do this but have it sorta look like it belongs there.
I think this is a pretty good read, explains the 2 different systems of radiator recovery.
I think the conventional vented recover is best for our old cars because we usually don't have room to mount the pressurized type recovery tank above the radiator. Read this.
[Re: Challenger 1]
#1668644
09/07/14 10:22 PM
09/07/14 10:22 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
good read and yes that's what i'd like to find. something to vent to that looks kinda 'right'. my Coke can and duct tape system doesn't really cut it! ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: 451Mopar]
#1668646
09/08/14 04:01 AM
09/08/14 04:01 AM
Posts: 27,480 So Cal
autoxcuda
So Cal
Bolt this tucked up under your passenger front fender to the fender bolt that protrude underneath it. You can use longer than stock fender bolts. Then run a long overflow hose through a existing inner fender or radiator support hole. Next paint the whole bottle semi flat black to match the underside of the fender. No one will notice. ![](http://boatsurveyshawaii.com/images/universaloverflow.gif)
[Re: can.al]
#1668647
09/08/14 10:43 PM
09/08/14 10:43 PM
mikemee1331
bethlehem pa
this on my '70 Duster and comes with a small bracket that you snap it on with. it's off a 2003 ...anybody recognize it?
I give. 2003 what? I also like the through the fender idea. where did you find that one autoxcuda?
[Re: mikemee1331]
#1668649
09/09/14 12:24 AM
09/09/14 12:24 AM
autoxcuda
So Cal
Just google image coolant overflow tank
It's the cheapie one in about every parts store.
Here's one installed ![](/ubbthreads/images/graemlins/scope.gif)
[Re: terzmo]
#1668654
09/09/14 10:05 PM
09/09/14 10:05 PM
mikemee1331
bethlehem pa
real cars don't use plastic...
so stick with the Coke can or should it be a beer can? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: mikemee1331]
#1668655
09/09/14 10:46 PM
09/09/14 10:46 PM
Challenger 1
Cincinnati, Ohio
I say beer. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: second 70]
#1668657
09/09/14 11:07 PM
09/09/14 11:07 PM
Posts: 21,845 Kirkland, Washington
Pacnorthcuda
Mike I use the wiper tank for my overflow on my cuda. Just hook hose to the bottom of tank and then you MUST drill a hole in the top rear of the tank to keep it from air locking. Works great and no one even knows it's being used this way. In 5 years use it has never had any problems. And yes that cap will work. Mike
I also converted the washer bottle on a 70 'Cuda to a recovery system and it works great. A breather hole is not required as the stock flip caps are incapable of holding a vacuum.
