Re: Bog when Engine is Warm [Re: cjskotni] #1668002
09/07/14 01:31 PM
09/07/14 01:31 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Problem with most dyno tunes is that the tune WOT. Transition and driveability are not addressed other than to make sure it isn't totally horrible.
Your best best bet is to install a wideband O2 and data logger to tune it right. Otherwise your sorta guessing what needs to be done.
Don't be the exception.
Re: Bog when Engine is Warm [Re: Supercuda] #1668003
09/13/14 04:51 PM
09/13/14 04:51 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
I plan on breaking into this soon when I have some spare time. In the meanwhile, what do you guys run as far as cam/nozzle size on your BB strokers?
Mine is a 400>>499 relatively mild as far as cam goes. What size nozzle would you guys 'expect' to see on this kind of motor? I know a lot goes into what it will end up taking but is a 42 'off the charts'?
The only thing I have to compare to is my friend's SBC 350 which takes a 32 IIRC but much smaller motor....
Re: Bog when Engine is Warm [Re: cjskotni] #1668004
09/14/14 01:17 AM
09/14/14 01:17 AM
NC, USA
davenc Offline
davenc  Offline
NC, USA
On a dual-plane manifold, a 042 shooter seems quite large. As others have mentioned, the pink cam may not be the best for a street car since it is lazy in lift right off idle. I would suggest changing the pump cam first, and then come back down on the shooter. Every setup is slightly different. Try an orange cam to start. I suspect the shooter can come down into the range of 031 with the right cam but change one thing at a time. In my opinion, the cam is the more important of the two on a street car.
Re: Bog when Engine is Warm [Re: davenc] #1668005
09/14/14 01:20 PM
09/14/14 01:20 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
FWIW I have the MP single plane manifold, not a dual plane.
I played around a little today with the car (more trying to test for vapor lock) but got it good and hot and tried to note this issue. It seems the bog only occurs if the throttle is blipped pretty fast and over 50% or so. Just giving it some moderate pedal or a blip under half throttle seems fine...no bog.
If the bog occurs at quick throttle opening over 50%, this means I need a cam that gives more fuel in that range (>50%)?
Either way, I will get my buddy's set of cams and try the red or orange and see what happens. I have a 32/38/42 squirters here I can try later if that helps the problem.
Thanks so much guys!
Re: Bog when Engine is Warm [Re: cjskotni] #1668006
09/14/14 08:25 PM
09/14/14 08:25 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
Was the "blip" with no load on the motor, or while the vehicle is in motion? If it stumbles or bogs with no load, then the setup is farther off.
You are correct about perhaps needing more cam lift above half-throttle. Note though that a smaller squirter will extend the duration of the pump shot. I still feel it is best to get the right cam first, and then fine tune with the squirter.
The chart you posted is helpful but does not show the effect of the two cam positions. If your motor is fine just off idle, you can try your current cam in the other position so that the lift occurs at higher throttle position degrees.
Re: Bog when Engine is Warm [Re: davenc] #1668007
09/14/14 08:45 PM
09/14/14 08:45 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
I did the blip with the car rolling and/or at a standstill in gear so under a load. The engine doesn't stumble at all when it's out of gear so not that far off!
Re: Bog when Engine is Warm [Re: cjskotni] #1668008
02/23/15 06:05 PM
02/23/15 06:05 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Ok guys,
I know it's been awhile since I posted this but I finally have the restoration part of the car done so now I have more time to circle back on these little mechanical gremlins.
I got the Holley tuning kit and swapped in the red cam (from the pink there) and went to a 37 squirter (from 42).
I had to shorten up the accel pump lever adjustment screw a lot...like 7-8 turns to get it where it was just resting on the pump lever with the throttle closed. I did the 15 thousandths feeler gauge as well on open throttle to make sure it didn't over extend the arm and all is good there.
Whoa what a difference! I scared myself a time or two when I blipped the throttle. Now I can break the tires loose at 40 mph when I blip it!
Of course now I notice that when I have it under WOT for more than 2-3 seconds, it is pinging a little bit so I guess it's time to roll the timing back a degree or two. Man that stroker can pull now!
Thanks guys!
Re: Bog when Engine is Warm [Re: cjskotni] #1668009
02/23/15 06:45 PM
02/23/15 06:45 PM
Thanks guys!
You sound pumped! On the timing you might go to a slightly heavier spring for either of the two springs in there (I'm assuming 2 light ones) until the pinging stops under WOT, since if your initial and total are correct as is you would not want to compromise them for the pinging
Re: Bog when Engine is Warm [Re: RapidRobert] #1668010
03/07/15 05:43 PM
03/07/15 05:43 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Thanks guys!
I measured the total timing which is 36 degrees...so 20 degree advance (16 initial). Do you have a part number and a recommendation as to what springs I need to use to back this down to maybe a 16-18 degree advance? This is the standard MP distributor.
Thanks!
Re: Bog when Engine is Warm [Re: cjskotni] #1668011
03/08/15 02:25 AM
03/08/15 02:25 AM
I measured the total timing which is 36 degrees...so 20 degree advance (16 initial). Do you have a part number and a recommendation as to what springs I need to use to back this down to maybe a 16-18 degree advance? This is the standard MP distributor. Thanks!
springs will not change the total only the RPM that the 36 total occurs. A heavier spring or springs makes the 20 deg slope to occur (start/end) at a higher RPM at any point in the slope (& less advance=less pinging). (1) see (& post) what springs are in there now (2) with your dialback & tach note the RPM that the adv stop advancing (that's when the slots are maxed). Here's a chart for a start tho the crane springs mentioned are no longer available but Ace hardware springs work just need to experiment with a slightly heavier one till you get just under the pinging point at WOT up thru the gears & the slope is linear whether you change one or both springs
Re: Bog when Engine is Warm [Re: RapidRobert] #1668012
03/08/15 12:08 PM
03/08/15 12:08 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
The advance doesn't stop until the engine is in the 2500 RPM range from what I saw. Wouldn't it be better to shorten the slots to just limit the timing advance?
I am not proficient with a welder so doesn't somebody make a plate that does this? I seem to remember somebody had a plate with various slots to limit the advance to 18/16/etc increments. EDIT: This is what I am talking about.
Any ideas? Does it work?
Re: Bog when Engine is Warm [Re: cjskotni] #1668013
03/08/15 01:49 PM
03/08/15 01:49 PM
Wouldn't it be better to shorten the slots to just limit the timing advance? Any ideas? Does it work?
(1) no (2) of course! (3) yes I hear the FBO plate works OK but 36 total is fine but it coming in too fast. 35 is a tried & true total for a std sb but strokers do have alightly different tiotal requirements but 36 ain't a dealbreaker. I am a fan of experimentation & wouldn't see an issue with trying the plate and or going to a heavier spring & seeing which one of the two works the best for your app. I'm sure the plate is cheap. EDIT Do you have a BB or SB? If BB I would stay at 36 & go to a heavier spring
Re: Bog when Engine is Warm [Re: RapidRobert] #1668014
03/08/15 03:46 PM
03/08/15 03:46 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
It's a B stroker 400>>499.
Re: Bog when Engine is Warm [Re: cjskotni] #1668015
03/08/15 04:12 PM
03/08/15 04:12 PM
Thanks guys!
Two suggestions, try a 32 or 35 squirter next,get the smalest one in it that won't bog with the accelerator pump arm set up properly At the same time back the timing up to 34 degrees total with the motor at or above 4000 RPM Don't change the amount of mechanical advance , just the initial If it still pings try a colder plug by one heat range lower BTW, what brand and heat range, plug number, are you running now? Now that you have opened the door to more power we need to maximise it so you can really get pump up, scare the poop out of you Mopowered
Re: Bog when Engine is Warm [Re: Cab_Burge] #1668016
03/08/15 04:22 PM
03/08/15 04:22 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
With the dizzy advancing 20*, this would mean only 14* of intial timing. On the dyno, we determined that the engine made the most power with 18* initial but of course pinged when you opened it up.
I don't think rolling back to 14* is enough timing?
I am running Champion RC12YC.
EDIT: I am going to try Autolite 3923 which is one heat step down from these Champions. I am guessing with the 10.4:1 compression this might not be a bad idea.
Re: Bog when Engine is Warm [Re: cjskotni] #1668017
03/08/15 06:16 PM
03/08/15 06:16 PM
You need more octane, if you build a monster you gotta feed it want it wants (needs). You're timing numbers ain't out of line but your SCR (& therefore DCR) is too high for your (current) choice of fuel.
Re: Bog when Engine is Warm [Re: RapidRobert] #1668018
03/09/15 08:45 AM
03/09/15 08:45 AM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
I realize this number is high but I am running aluminum heads. I know people here have run much higher with pump fuel.
BTW I did take it out today with the colder plugs and took it up to WOT for a few seconds...enough to open the the secondaries and I didn't hear any pinging. I will keep testing and maybe try a heavier spring as well...
Re: Bog when Engine is Warm [Re: cjskotni] #1668019
03/09/15 12:48 PM
03/09/15 12:48 PM
Man I had no idea a colder plug would make that much difference , if it ain't pinging you're set
Re: Bog when Engine is Warm [Re: cjskotni] #1668020
03/09/15 04:35 PM
03/09/15 04:35 PM
Buy a set of Champion RC9YC and try them later Change them squirters also That way it will really smoke them hind tires at speed
