Page 2 of 3 1 2 3
Re: Radiator Coolant Recovery Tank [Re: YO7_A66] #1666522
09/03/14 04:07 PM
09/03/14 04:07 PM
central il.
second 70 Offline
second 70  Offline
central il.
Yes as far as I know. 18lbs #52027793 Looks like the ones in challenger's pictures.
Re: Radiator Coolant Recovery Tank [Re: second 70] #1666523
09/03/14 04:29 PM
09/03/14 04:29 PM
Indiana
Y
YO7_A66 Online content OP
YO7_A66  Online Content OP
Y
Indiana
I bought the Stant #10231 radiator cap yesterday. The description shows:
""Designed to function on open cooling systems and overflow reservoir type systems".
It looks to be a dual purpose cap.
www.sportinggoodsoutdoor.com/p/detail/B000B8N3GE/Stant-10231-Radiator-Cap-16-PSI-Vented.html
Re: Radiator Coolant Recovery Tank [Re: YO7_A66] #1666524
09/03/14 04:30 PM
09/03/14 04:30 PM
central il.
second 70 Offline
second 70  Offline
central il.
Mike,
Do you run the stock radiator cap?
O'reilly 7616 $4.99
Re: Radiator Coolant Recovery Tank [Re: YO7_A66] #1666525
09/03/14 04:34 PM
09/03/14 04:34 PM
central il.
second 70 Offline
second 70  Offline
central il.
Should work I used the other just to look more stock.
Re: Radiator Coolant Recovery Tank [Re: YO7_A66] #1666526
09/03/14 04:43 PM
09/03/14 04:43 PM
NO RUST IN AZ!!!
azmopar Offline
Happy Birthday azmopar  Offline
NO RUST IN AZ!!!
Dornman 603-703.
IF youre using this one I have one
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: Radiator Coolant Recovery Tank [Re: azmopar] #1666527
09/03/14 04:46 PM
09/03/14 04:46 PM
Indiana
Y
Y
Indiana
Can you show us pictures of where you mounted it?
Re: Radiator Coolant Recovery Tank [Re: YO7_A66] #1666528
09/03/14 04:46 PM
09/03/14 04:46 PM
NO RUST IN AZ!!!
azmopar Offline
NO RUST IN AZ!!!
im not using one I just happen to have one here at work lol
#NONIKESEVER
Re: Radiator Coolant Recovery Tank [Re: azmopar] #1666529
09/03/14 05:07 PM
09/03/14 05:07 PM
Indiana
Y
Y
Indiana
Got it.
Re: Radiator Coolant Recovery Tank [Re: second 70] #1666530
09/04/14 09:11 AM
09/04/14 09:11 AM
Indiana
Y
Y
Indiana
""I used the wiper tank on my hemi cuda and it works great.""
I removed my washer tank last night and cleaned it out while I inspected the condition. It appears to be the original tank and I am very suspicious of the fitting on the bottom side holding any type of fluid. If it was newer, I would look into reusing it as a coolant recovery tank, but in it's current condition I would be worried about it holding fluid. Thank you Mike for posting the details on converting it over!!
I think that I am going to purchase the dorman 603-121 pressurized recovery tank and then determine the best mounting location once I have it in hand. I will probably mount it in front of the radiator support on the passenger side (more hidden) or just mount it to the passenger side frame rail under the two horns depending on the actual size of the unit.
Thanks again for all of the replies.
Re: Radiator Coolant Recovery Tank [Re: YO7_A66] #1666531
09/06/14 11:50 PM
09/06/14 11:50 PM
Indiana
Y
Y
Indiana
I installed the above 603-121 pressurized tank with the Stant radiator cap. I modified the lower return opening by removing the brass sleeve and tapping the hole for a 3/8npt bushing. I added sealant to the threads and then screwed in a 1/4npt (w/sealant) with a barb fitting. The existing overflow hose was cut to length and then I added an overflow hose to the upper portion of the tank. I used the existing horn mounting bolt so no holes were added to the inner fender. I will add coolant in the tank tomorrow and test drive it for leaks.
Thanks for the replies!!
Re: Radiator Coolant Recovery Tank [Re: YO7_A66] #1666532
09/06/14 11:51 PM
09/06/14 11:51 PM
Indiana
Y
Y
Indiana
another
Re: Radiator Coolant Recovery Tank [Re: YO7_A66] #1666533
09/07/14 09:13 AM
09/07/14 09:13 AM
BDW Offline
BDW  Offline
What kind of radiator is that, I'd like to do similar, but the nipple on my radiator exits on the driver's side.
Like the idea of putting something over by the horns, plenty of room.
Re: Radiator Coolant Recovery Tank [Re: BDW] #1666534
09/07/14 10:30 AM
09/07/14 10:30 AM
Indiana
Y
Y
Indiana
I got lucky with the radiator as it came with the car when I bought it. It is a "927" unit:
""Large 26" Radiator core from a Mopar B-Body Road Runner, Charger or Super Bee with a 340 or 318 with A/C. This has the integral transmission cooler, but was used for both manual and automatic cars. Chrysler part no. 3673927.""
Re: Radiator Coolant Recovery Tank [Re: Challenger 1] #1666535
09/07/14 01:31 PM
09/07/14 01:31 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I am looking at adding a coolant recovery tank on my 70 Challenger. I have been looking at what is available through Dorman and I found their universal unit (603-001) and I also came across #603-121 (1992-2002 Saturn) pictured. So far I like it better because it looks smaller and I could mount it in front of the radiator support which might hide it a litter better.
http://www.dormanproducts.com/p-44832-603-121.aspx
I am looking for other ideas on what style/part number of unit and where did you mount yours on the older cars.
I used a 73-74 repo and bracket for my 74, it'll fit all other E body's also.
Sorry for the late response, but as I have a 74, this idea was what I was thinking when I read the OP. Its stock albeit not correct. However if you're adding it, year correctness isn't an apparent concern
Scott
Re: Radiator Coolant Recovery Tank [Re: YO7_A66] #1666536
09/07/14 02:09 PM
09/07/14 02:09 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Check this out... web page
It looks like your tank is a little low if it's a pressurized tank. And a pressurized tank is supposed to used to fill the radiator because it usually mounted higher than the top of the radiator. And it usually has a larger hose that comes of it to fill the radiator. (I'd tee off a heater hose possibly if I were to install a pressurized over flow tank in our old cars). Good luck with yours. Does it have a hose inside that goes to the bottom is it's not pressurized and vented?
Re: Radiator Coolant Recovery Tank [Re: Challenger 1] #1666537
09/07/14 06:12 PM
09/07/14 06:12 PM
Indiana
Y
Y
Indiana
It appears that I had my terminoly wrong. I am aiming for the Zero Pressure setup:
""The ZERO PRESSURE tank will recover the expanded coolant as it increases in pressure. Once the pressure exceeds 15 PSI the big spring on the radiator cap will be overcome by the pressure and allow some small amounts of coolant to dump to the ZERO PRESSURE tank. Later, when the coolant cools off inside the engine it will create a vacuum as the coolant changes to its normal unexpanded size. A small vent in the radiator cap will now open and draw the coolant back into the radiator so the cycle can start over again in the next driving event""
Thanks for the reply.
Re: Radiator Coolant Recovery Tank [Re: YO7_A66] #1666538
09/27/14 10:52 PM
09/27/14 10:52 PM
Indiana
Y
Y
Indiana
I have been driving with the recovery tank in place and I have a quick question.
Do I keep filling the recovery tank when the level drops to the bottom?
I have now added coolant to the recovery tank three times now since the install and after my drive today, the fluid was down at the bottom of the tank again after the engine cooled. It is not leaking and my oil level is correct. It just seems that it is pulling in more coolant into the radiator than I would have thought.
Re: Radiator Coolant Recovery Tank [Re: YO7_A66] #1666539
09/27/14 11:16 PM
09/27/14 11:16 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
stupid return question - are you using the right radiator cap with this type of recovery system? it's not the standard non-recovery cap that would have been used. it's supposed to have some sort of a 'weep' hole for the system to pull back the fluid but where else could it have gone unless it is evaporating?? also, in the recovery can cap tight? I know on my kids Sunfire if the recovery cap is at all loose the fluid disappears!
Re: Radiator Coolant Recovery Tank [Re: mikemee1331] #1666540
09/28/14 01:02 AM
09/28/14 01:02 AM
Indiana
Y
Y
Indiana
Correct cap and tank cap is tight.
Re: Radiator Coolant Recovery Tank [Re: YO7_A66] #1666541
09/28/14 12:47 PM
09/28/14 12:47 PM
Indiana
Y
Y
Indiana
Before I drove the car this morning, I removed the radiator cap to find the level AT THE TOP. Now I know it is full so I filled up the recovery tank about 3/4 up. After a long drive the tank was still at the same level. After a few hours of cool down time, the level was about an inch lower so I am hoping that the system is now full.
I am surprised how much more coolant a 26" radiator will hold once the overflow hose is connected to a reservoir tank. At least another gallon of water/coolant.
Page 2 of 3 1 2 3
