Re: Auto trans guys, what am I looking at here??....... [Re: Guitar Jones] #1666335
09/03/14 12:00 AM
09/03/14 12:00 AM
Socal
littleVAL Offline
littleVAL  Offline
Socal
that could not be coolant mixed in it
Re: Auto trans guys, what am I looking at here??....... [Re: Guitar Jones] #1666336
09/03/14 10:22 AM
09/03/14 10:22 AM
Akron, Ohio U.S.A.
roadhazard Offline OP
Akron, Ohio U.S.A.
Just loosen the valve body bolts and pull it down about an 1/8 of an inch. Let it drain, push it back up by hand then tighten the bolts.
Will do sir
While I'm in there may as well use a can or two of brake clean to get out what I can.
Any suggestions on band adjustment?
What is it.... torque to 73 lb,in then back off how many turns?
I'll note the position of the adjuster to start and see if it takes a lot to put back in adjustment.
No coolant in there.... cooler is separate from the radiator.
Re: Auto trans guys, what am I looking at here??....... [Re: roadhazard] #1666337
09/03/14 10:30 AM
09/03/14 10:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Will do sir
72 inch lbs.. then back off(this part depends on the
VB that you have).. but anywhere between 2 to 2 1/2 turns
check with your VB company
Re: Auto trans guys, what am I looking at here??....... [Re: roadhazard] #1666338
09/03/14 06:20 PM
09/03/14 06:20 PM
oh
julian2007 Offline
julian2007  Offline
oh
you are suppose to adj the band every 25 laps w/ a alum drum.
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
Re: Auto trans guys, what am I looking at here??....... [Re: julian2007] #1666339
09/03/14 10:43 PM
09/03/14 10:43 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I have an aluminum drum in mine, change the fluid every 20-30 runs, filter every other. You mention Pro Trans if it's a Pro Trans that means rebuilt after 20-30 runs. I drive mine on street some, shouldn't need band adjustment if the fluid is changed as said above.
Re: Auto trans guys, what am I looking at here??....... [Re: julian2007] #1666340
09/04/14 03:36 PM
09/04/14 03:36 PM
oh
julian2007 Offline
julian2007  Offline
oh
I was instructed by A&A to adjust the band every 25-30 laps.
