Re: Auto trans guys, what am I looking at here??.......
[Re: Guitar Jones]
#1666336
09/03/14 10:22 AM
09/03/14 10:22 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Just loosen the valve body bolts and pull it down about an 1/8 of an inch. Let it drain, push it back up by hand then tighten the bolts.
Will do sir ![](/ubbthreads/images/graemlins/thumbs.gif) While I'm in there may as well use a can or two of brake clean to get out what I can.
Any suggestions on band adjustment? What is it.... torque to 73 lb,in then back off how many turns? I'll note the position of the adjuster to start and see if it takes a lot to put back in adjustment.
No coolant in there.... cooler is separate from the radiator.
[Re: roadhazard]
#1666337
09/03/14 10:30 AM
09/03/14 10:30 AM
Posts: 52,972 Romeo MI
MR_P_BODY
72 inch lbs.. then back off(this part depends on the VB that you have).. but anywhere between 2 to 2 1/2 turns check with your VB company ![](/ubbthreads/images/graemlins/wave.gif)
[Re: julian2007]
#1666340
09/04/14 03:36 PM
09/04/14 03:36 PM
Posts: 901 oh
julian2007
oh
I was instructed by A&A to adjust the band every 25-30 laps.
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
