Re: 1968 Hemi Dodge Dart rear wheel well template help....
[Re: Chryco69]
#1666249
09/01/14 04:09 PM
09/01/14 04:09 PM
Posts: 190 Indiana
Chryco69
Missing my hose
Missing my hose
Indiana
[Re: Chryco69]
#1666250
09/01/14 04:10 PM
09/01/14 04:10 PM
Posts: 190 Indiana
Chryco69
Missing my hose
Missing my hose
Indiana
[Re: Chryco69]
#1666251
09/01/14 04:11 PM
09/01/14 04:11 PM
Posts: 190 Indiana
Chryco69
Missing my hose
Missing my hose
Indiana
[Re: Chryco69]
#1666252
09/01/14 04:11 PM
09/01/14 04:11 PM
Posts: 190 Indiana
Chryco69
Missing my hose
Missing my hose
Indiana
[Re: Chryco69]
#1666253
09/01/14 04:12 PM
09/01/14 04:12 PM
Posts: 190 Indiana
Chryco69
Missing my hose
Missing my hose
Indiana
[Re: RSNOMO]
#1666255
09/01/14 04:30 PM
09/01/14 04:30 PM
Posts: 190 Indiana
Chryco69
Missing my hose
Missing my hose
Indiana
Get ahold of Steve Atwell...
He's here, in Rochester Hills I believe...
He knows LO23's...
What is his username?
[Re: RSNOMO]
#1666257
09/01/14 05:11 PM
09/01/14 05:11 PM
Posts: 44,062 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I found out years ago that if you take a passenger side front fender and set it up against the drivers side quarter the outline is perfect. Here is a pic of my original Hemi Dart for comparison...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#1666258
09/01/14 05:20 PM
09/01/14 05:20 PM
Posts: 190 Indiana
Chryco69
Missing my hose
Missing my hose
Indiana
What are you lining it up to?
[Re: Rhinodart]
#1666259
09/01/14 05:57 PM
09/01/14 05:57 PM
Posts: 18,167 Mass
DAYCLONA
Mass
Exactly, the front fender opening is the template for the rear, but that's your starting point for a Hurst rendition, IMHO your better off installing the tire you plan on running, mock up your own template opening based on the front fender opening, then measure twice, cut once, rather than trim, trim, trim, then mount the tire of choice, and trim again
[Re: DAYCLONA]
#1666260
09/01/14 06:21 PM
09/01/14 06:21 PM
Posts: 190 Indiana
Chryco69
Missing my hose
Missing my hose
Indiana
Ok but how are you lining it up to cut it??? Can anyone confirm this to be true? I just don't want the car to be butchered, I am trying to build a replica as close as possible.
[Re: Chryco69]
#1666261
09/01/14 06:28 PM
09/01/14 06:28 PM
Rhinodart
Rhinotruck
Rhinotruck
That is the tough part, nobody seems to know exactly how it was done originally. I know several people that have used the O'reilly template and it looked fine. I have seen other templates for sale but do not know for sure where they come from. If you look at a factory car, it is butchered. If you are trying to get a factory looking car it will look like shinola. My car has been butchered through the years worse than the factory did it. I believe all the templates have been drawn off of factory cars, so that is why they are all a little different.
A-Body's RULE!
[Re: Rhinodart]
#1666262
09/01/14 06:36 PM
09/01/14 06:36 PM
Posts: 190 Indiana
Chryco69
Missing my hose
Missing my hose
Indiana
The issue with the Reilly template is that it requires you to remove to much from the front. If I were to follow the template, I would have to re-weld part of it back on because the template goes past the inner wheel well.
[Re: 3ddart]
#1666267
09/01/14 08:20 PM
09/01/14 08:20 PM
Posts: 27,610 So Cal
autoxcuda
So Cal
