Re: mini-starter woes.. [Re: mikemee1331] #1666050
09/01/14 11:44 PM
09/01/14 11:44 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
I wouldnt want to cut the snout - i think it may weaken
It . Maybe not. I guess 30 thou wont hurt but definitely
A shim helped me with mp block
Re: mini-starter woes.. [Re: sogtx] #1666051
09/02/14 02:06 AM
09/02/14 02:06 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
That's why I hate this new crap. I guess I better pull the bellhousing off and pull mine out the back so I can grind the little beauty. Glad I didn't lift the trans in today. I shoved mine in by hand and it went in nice but I don't like taking chances. First time I've used one of these silly little starters ever. I always use the best original old style I can find but I'm starting to run out of good ones.
Sheldon
Re: mini-starter woes.. [Re: RUNCHARGER] #1666052
09/02/14 05:49 AM
09/02/14 05:49 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Only way to go unless yer goin' fer OEM gold...
I've run a mini w/heat shield for 20 years with no issues...
And that's captured around tubes de la Hookeare...
Like Mike mentioned, POS stud can be tight, but beyond that, I'd never go back to OEM...
Which wasn't gonna fly with the Hooker's anyway...
Re: mini-starter woes.. [Re: mikemee1331] #1666053
09/02/14 04:37 PM
09/02/14 04:37 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ma never used a shim.that is basicaly a cover to keep crap out of the bell area.Ive run without them since the 60s and never had a problem.Most problems are caused by not having the starter seated correctly.Oh my mini in a 12.5 440 has been in for at least 15 years.Still cranks like a /6.Rocky
Chrysler Firepower
Re: mini-starter woes.. [Re: therocks] #1666054
09/02/14 05:37 PM
09/02/14 05:37 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
I am starting to think my new torque converter's ring gear total diameter isn't up to snuff........
Troy
Houston Mopar Connection Club
Re: mini-starter woes.. [Re: therocks] #1666055
09/02/14 07:42 PM
09/02/14 07:42 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Rocky, I not advocating shims or grinding. just answering his questions. there is 'something' not straight or he's using the wrong mini-starter based on all I've read. I still use the good old fashion 200 lb pain in the rump stock one. why? cause I've got a lifetime warranty from National Auto from 25 years ago and someday, someday I will get to cash it in!
Re: mini-starter woes.. [Re: mikemee1331] #1666056
09/03/14 01:41 AM
09/03/14 01:41 AM
RUNCHARGER Offline
RUNCHARGER  Offline
Well, I made a shim for mine and I think I can wiggle it out without taking off the bellhousing/ Of course the wrench is too long to make a turn between the Hooker header and the T-bar. Didn't want to cut one of my good home wrenches so I'll cut one of the wrenches down from work tomorrow. I'll look at the mini and see if I can grind some off of it to facilitate a socket. Hopefully if I go through all of this I'll never have to pull the lil devil ever again.
Sheldon
Re: mini-starter woes.. [Re: RUNCHARGER] #1666057
09/07/14 05:24 AM
09/07/14 05:24 AM
france
jose jones Offline
jose jones  Offline
france
I had a 2500 stall converter in a stroker RR, the teeth didn't engage very well the converter,It had bolts the same size as the crank bolts and as such the welded nuts were thicker on the converter, I took the converter back to Hughes in Phoenix, they welded the ring gear 1/4 of a inch forward towards the back of the engine,never had a problem with the starter again,not sure if this is your problem, but it solved mine
Re: mini-starter woes.. [Re: jose jones] #1666058
09/15/14 11:18 PM
09/15/14 11:18 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
So how did it go ?
