Re: Boring a 273 Block to a 340 Block
[Re: MR_P_BODY]
#1666005
09/01/14 12:47 AM
09/01/14 12:47 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Only due to the cyl walls not being thick enough
So the 340 block has a little more "meat" built into it? Are they the same size, physically, on the outside?
[Re: MuuMuu101]
#1666006
09/01/14 12:56 AM
09/01/14 12:56 AM
Posts: 52,972 Romeo MI
MR_P_BODY
They are the same size on the outside.. but the 340 starts out with a larger bore due to the sand casting and a smaller water area between the cyls.. the inside is cast different in the bore areas.. yes they can be bored and sleeved but a 273 isnt worth it
[Re: MuuMuu101]
#1666007
09/01/14 02:25 AM
09/01/14 02:25 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
MuuMuu there are a ton of small block combos you could build, but bang for the buck it is hard to beat a warmed over 360 for a street car.
If the budget is a little bigger a 408 with some cylinder head is a fun way to go.
But it is a slippery slope when it comes to how much is enough when it comes to go fast stuff.
"Just a Bracket car dressed up like a streetcar"
[Re: Copper Dart]
#1666009
09/01/14 11:59 AM
09/01/14 11:59 AM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
Engine Build Warning: Use Extreme Caution or just throw the "budget" out the window! DAMHIK
Truer words have never been spoken.
[Re: G_bob]
#1666010
09/01/14 01:37 PM
09/01/14 01:37 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
x2 100%. All LA motors have the same bore centers, the difference being the thickness of the wall castings. Which is why Mopar separated them into two sub-family groups: 273/318 and the 340/360. The walls of the 273 may not be able to be bored even to the 318 size (3.91"), without sonic testing (273 is 3.63" bore). Depending on the year and whether the block can take an overbore, chances are next to nil to increase the bore to the 340 piston size. Sorry. On the bright side , the 273, CAN take increased stroke length, adding MORE TORQUE to the motor .
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
[Re: MuuMuu101]
#1666012
09/01/14 02:41 PM
09/01/14 02:41 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have a 318 block that is 4.070 bore and when you tap on the cylinder walls they sound like glass, it was a running dirt track engine 12.5 compression with a rod knock when I picked it up I am scared to re assemble it, I bet a 273 at that bore would have huge holes in the cylinder at that bore.
[Re: G_bob]
#1666013
09/01/14 02:50 PM
09/01/14 02:50 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
What is this thing you call a "budget?"
I knew there was something different about the 273/318 blocks vs. the 340/360 blocks. I was just curious what that difference was.
I've talked to a couple members here and FABO and it definitely seems like quite a bit of work to get a 273 to go quick on pump gas. Even if built to D-Dart specs or a little better that only puts you at about 300 hp which is more easily achievable with any other small block.
A guy on FABO is building a mild 408 or 410 with turbos and is expecting to make 700 hp on 91 octane... Is that fast enough?
http://www.forabodiesonly.com/mopar/showthread.php?t=116512
[Re: J_BODY]
#1666017
09/01/14 07:32 PM
09/01/14 07:32 PM
MR_P_BODY
I've got a stock forged(all the 273s had forged cranks) but if you want to use a auto behind it CHECK the center counter bore for the auto.. mine is a stick crank and the conv wont fit as is
