Boring a 273 Block to a 340 Block #1666002
09/01/14 12:35 AM
09/01/14 12:35 AM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
So, I don't hang around these parts very often. Let's just say I have a standard bore 273 block and would like a 340 block. Couldn't I theoretically have a machinist bore out the cylinders .410" and have a 340 block since the strokes are the same? Or would there be other problems I don't know about?
Re: Boring a 273 Block to a 340 Block [Re: MuuMuu101] #1666003
09/01/14 12:38 AM
09/01/14 12:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Only due to the cyl walls not being thick enough
Re: Boring a 273 Block to a 340 Block [Re: MR_P_BODY] #1666004
09/01/14 12:45 AM
09/01/14 12:45 AM
NC
barracuda man Offline
NC
can it be sleeved?then bored.
Re: Boring a 273 Block to a 340 Block [Re: MR_P_BODY] #1666005
09/01/14 12:47 AM
09/01/14 12:47 AM
SoCal
SoCal
So the 340 block has a little more "meat" built into it? Are they the same size, physically, on the outside?
Re: Boring a 273 Block to a 340 Block [Re: MuuMuu101] #1666006
09/01/14 12:56 AM
09/01/14 12:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
They are the same size on the outside.. but the 340
starts out with a larger bore due to the sand casting
and a smaller water area between the cyls.. the inside
is cast different in the bore areas.. yes they can
be bored and sleeved but a 273 isnt worth it
Re: Boring a 273 Block to a 340 Block [Re: MuuMuu101] #1666007
09/01/14 02:25 AM
09/01/14 02:25 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
MuuMuu there are a ton of small block combos you could build, but bang for the buck it is hard to beat a warmed over 360 for a street car.
If the budget is a little bigger a 408 with some cylinder head is a fun way to go.
But it is a slippery slope when it comes to how much is enough when it comes to go fast stuff.
"Just a Bracket car dressed up like a streetcar"
Re: Boring a 273 Block to a 340 Block [Re: Just-a-dart] #1666008
09/01/14 09:57 AM
09/01/14 09:57 AM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
Engine Build Warning:
Use Extreme Caution or just throw the "budget" out the window!
DAMHIK
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Boring a 273 Block to a 340 Block [Re: Copper Dart] #1666009
09/01/14 11:59 AM
09/01/14 11:59 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
DAMHIK
Truer words have never been spoken.
Re: Boring a 273 Block to a 340 Block [Re: G_bob] #1666010
09/01/14 01:37 PM
09/01/14 01:37 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
DAMHIK
x2 100%. All LA motors have the same bore centers, the difference being the thickness
of the wall castings. Which is why Mopar separated them into two sub-family groups: 273/318 and the 340/360. The walls of the 273 may not be able to be bored even to the 318 size (3.91"), without sonic testing (273 is 3.63" bore). Depending on the year and whether the block can take an overbore, chances are next to nil to increase the bore to the 340 piston size. Sorry. On the bright side , the 273, CAN take increased stroke length, adding MORE TORQUE to the motor .
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Boring a 273 Block to a 340 Block [Re: Just-a-dart] #1666011
09/01/14 01:46 PM
09/01/14 01:46 PM
Desert Tracker
Desert Tracker
The 408 is a natural for street/strip action and if that is not enough motor for you, there are increased displacements all the way to the "popular" 426 cube mark. A 340 or 360 block can be used.
Re: Boring a 273 Block to a 340 Block [Re: MuuMuu101] #1666012
09/01/14 02:41 PM
09/01/14 02:41 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have a 318 block that is 4.070 bore and when you tap on the cylinder walls they sound like glass, it was a running dirt track engine 12.5 compression with a rod knock when I picked it up
I am scared to re assemble it, I bet a 273 at that bore would have huge holes in the cylinder at that bore.
Re: Boring a 273 Block to a 340 Block [Re: G_bob] #1666013
09/01/14 02:50 PM
09/01/14 02:50 PM
SoCal
SoCal
DAMHIK
What is this thing you call a "budget?"
I knew there was something different about the 273/318 blocks vs. the 340/360 blocks. I was just curious what that difference was.
I've talked to a couple members here and FABO and it definitely seems like quite a bit of work to get a 273 to go quick on pump gas. Even if built to D-Dart specs or a little better that only puts you at about 300 hp which is more easily achievable with any other small block.
A guy on FABO is building a mild 408 or 410 with turbos and is expecting to make 700 hp on 91 octane... Is that fast enough?
http://www.forabodiesonly.com/mopar/showthread.php?t=116512
Re: Boring a 273 Block to a 340 Block [Re: MuuMuu101] #1666014
09/01/14 05:25 PM
09/01/14 05:25 PM
NC
NC
I have 2 of these 273ci engines both are 1967.one being the 235hp version the other 180hp.What are they good for other than a boat anchor.
Re: Boring a 273 Block to a 340 Block [Re: barracuda man] #1666015
09/01/14 06:44 PM
09/01/14 06:44 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Remove the adjustable rockers and shafts before you take them to the scrap yard, would be what comes to my mind
Re: Boring a 273 Block to a 340 Block [Re: Just-a-dart] #1666016
09/01/14 07:22 PM
09/01/14 07:22 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....and the crankshafts.
Re: Boring a 273 Block to a 340 Block [Re: J_BODY] #1666017
09/01/14 07:32 PM
09/01/14 07:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've got a stock forged(all the 273s had forged cranks)
but if you want to use a auto behind it CHECK the center
counter bore for the auto.. mine is a stick crank
and the conv wont fit as is
Re: Boring a 273 Block to a 340 Block [Re: MR_P_BODY] #1666018
09/01/14 07:36 PM
09/01/14 07:36 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
A Prestone cap was a quick check as to whether your torque converter hub would fit the crank.
Re: Boring a 273 Block to a 340 Block [Re: MR_P_BODY] #1666019
09/01/14 08:50 PM
09/01/14 08:50 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I've pulled apart a couple 69s that looked original after buying them for the cranks and found them to be cast
Re: Boring a 273 Block to a 340 Block [Re: HotRodDave] #1666020
09/01/14 09:00 PM
09/01/14 09:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Someone put 318 cranks in there
EDIT
if they were real late builds Chrysler could have
put them in if they were out of cranks.. they did
weird stuff all the time
Re: Boring a 273 Block to a 340 Block [Re: HotRodDave] #1666021
09/01/14 09:15 PM
09/01/14 09:15 PM
Desert Tracker
Desert Tracker
I think that Mopar went to cast cranks on the 273/318 after 67'. The 340 remained with the forged steel crank from 68' until late 72'. The 360 always had cast cranks since it's birth in 71' (with the larger diameter main bearings in comparison to the other three motors).
