426 HemiWedge - weird animal from Petty
#1665803
08/31/14 08:46 AM
08/31/14 08:46 AM
Posts: 208 Munich, Bavaria
docford
Munich, Bavaria
Hi there, I have a genuine HemiWedge, which was built by Maurice Petty and raced in NASCAR by both Richard Petty and Hershel McGriff. It is a 1969 HEMI block that was modified to accept Wedge heads. This was done in 1973-1976, when the HEMI had to run a way too small restrictor plate. So switching to Wedge heads allowed to run less restrictor plate and hence make more power. It runs the same crank, rods and in-pan dry sump system as the NASCAR HEMI, but has wedge heads, wedge pistons and a wedge camshaft. Here is a link to some technical specs: http://www.olympia-charger.com/2010/04/original-oly-express-426-wedge-v8-returns-home.htmlAnd here is a link about how I got it: http://www.olympia-charger.com/2012/09/p...at-le-mans.htmlI'd be interested to know more about these engines in order to make mine even better and possibly race it once in a while in my Dodge Charger. Any information is greatly appreciated
Re: 426 HemiWedge - weird animal from Petty
[Re: docford]
#1665804
08/31/14 10:35 AM
08/31/14 10:35 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Hi there,
We bought 6 of those blocks from Petty years ago.The last one we had left went to Ron McCelland in Beaverdale(Buds Auto Sales.He still has it.Threaded plugs were used to fill the valley bolt holes and the pattern was redrilled for the wedge head,plugs were also installed in the oil drain back holes at the lower deck corners and the lifter valley was clearenced for pushrods.
[Re: autoxcuda]
#1665812
08/31/14 03:29 PM
08/31/14 03:29 PM
Posts: 27,593 So Cal
autoxcuda
So Cal
[Re: autoxcuda]
#1665813
08/31/14 03:31 PM
08/31/14 03:31 PM
autoxcuda
So Cal
[Re: docford]
#1665814
09/01/14 01:15 AM
09/01/14 01:15 AM
Posts: 2,028 s. e. pa.
calrobb2000
s. e. pa.
hi , i have one piston and hemi rod assembly from one of those engines . cool pice of nastalga history !
[Re: AlexP]
#1665819
09/03/14 01:28 AM
09/03/14 01:28 AM
autoxcuda
So Cal
So the PE Catalog list part number #3751667.
Anyone have a way to find out what part number 3751667 is?
OK, I am looking at the that head picture page... It's hard to read, but I think the casting number on the underside of the head reads: 3462340 or 3462348 or 3462346
I'll assume that is a 3462346 head.
That's what's in the picture. I'd be interested in what that part number corresponded to.
If you look at that part number page, Petty offered a port and polished wedge head and a wedge head complete and blueprinted.
[Re: dogdays]
#1665821
09/03/14 03:25 PM
09/03/14 03:25 PM
Posts: 75,313 A gulag near you.
JohnRR
A gulag near you.
RE: 213 head. Some, but not all, got extra cooling holes near the spark plug, which was the "extra cooling" that other heads didn't have. They were small, maybe 5/32 diameter. These heads also used the 5/8" peanut plugs.
I have a pair of 213s that I took off a 400 in a passenger car and they use the regular plugs and have no cooling holes at the plug.
It has been my opinion on looking at a few different 213s that they had slightly smaller ports, nothing huge but looked that way to me. Could have been casting differences, I guess.
R.
I had a set of Paul Rossi Street fighter heads I bought back in 1988 that were 452's, they had the peanut plugs and cooling passages around them.
