Re: Big Block (440, 400, 383) vs. Small Block in A-body?
[Re: gdonovan]
#1665647
09/02/14 02:21 PM
09/02/14 02:21 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
You would save a lot of $$$ plus time and aggravation.
How do you save money? It will cost more to build a stroked small block (408) and than a stock stroke 440. Headers and mounts are going to be a wash either way and if going auto BB 727 are dime a dozen.
Unless you are going to build an "outer limits" small block, the 440 is going to have more cubes to work with. If building an "outer limits" small block you are going to be spending a lot of money on a proper race block which isn't cheap not to mention the proper heads to feed a small block 426/440
Also it won't be front heavy.
A relative argument.
A 440 with source heads, aluminum intake, headers and aluminum water pump housing would be lighter than a factory small block, I looked this up just out of idle curiosity.
No one ever has made the statement that I'm aware of that a *factory* 340 or 360 car is "nose heavy." A 440 dressed like I described would be no more nose heavy than a stocker 340/360.
Would a small block with also benefit in the weight reduction? Of course but again the small block is going to lose the cube war and will cost more to get there.
People put 906 heads on 440s all the time and it is plenty of head but an X head or magnum head will flow right there with it but they are "not enough head"? Also a magnum has a waaaaay more efficent chamber and valve placement so you can make more power with less timing and less fuel. A SB eddy flows more than a 906 so the head flow theory is out the window. If you want to get serious a properly done w9 will smoke an well done BB eddy, stealth...
TQ is nice but you can always make more TQ with gear ratio and HP is what makes you fast. I like TQ as much as the next guy but am not willing to sacrifice handling, ease of spark plug change.
BTW motor mounts are like free for a SB A body but good luck finding BB mounts for free, factory 318 and even 340-360 mounts are a dime a dozen
Also the aftermarket block comment is stupid also as the SB seems to hold up to just as many HP as a 440 block while being 35# lighter and no deep skirt.
Stroking a BB become a point of futility when your 700# TQ is snapping u joints, trannys, axles...
A SB stroker just does it all good, all the TQ most drivetrains can handle, light weight without buying water pump housing heads intake...
[Re: ademon]
#1665652
09/02/14 11:25 PM
09/02/14 11:25 PM
Posts: 4,672 Wichita
GY3
Wichita
Well the OP has the 440 with a cast crank so basically it's just a bare block since he says he wants a forged crank, the rest of the parts on the 440 are worthless. I would sell the complete 440 and use whatever money to buy a 400 or even get a free 383 block and stroke that since it will fit better and he wants a forged crank. Not sure how the A/C system will fit. Also not sure how the trans he is using holds up to high torque but that's a point to think about and maybe a quicker high reving SB might be more fun. My Stock stroke SB has put a lot of stroked BB to shame, why? I run drag radials on the street. If your going to the trouble of stuffing a big cube BB in it DO NOT run street tires! LOL
Hooking on the street is definitely an art form.
