Re: whats everyone running solid roller lifters on street?
[Re: quickd100]
#1665207
09/03/14 10:29 AM
09/03/14 10:29 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Isky Red Zone solid rollers in my hemi. Block doesn't even have lifter oil galleys.
[Re: StrokerAspen]
#1665208
09/03/14 10:39 AM
09/03/14 10:39 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I am running the Comp Cams 8043, I bought them from IMM engines.
Me too. Running 276/284 @ .050" done a fair amount of street miles.
-Kenny
I bought my lifters from Brian also (for my SB) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Hot 340]
#1665210
09/04/14 04:26 PM
09/04/14 04:26 PM
Posts: 5 usa ohio
bones427
usa ohio
Agressive profiles and lack of spring pressure is harder on rollers than anything. And if you run a morel style lifter you usually have to restrict oil in most setups
why do morels need restricted? I have them and have a oil pressure issue, wondering if it is the lifters causing it? have 40 lbs idle and pressure drops as rpm's go up.
[Re: bones427]
#1665211
09/04/14 10:20 PM
09/04/14 10:20 PM
Posts: 3,396 Pa
Hot 340
Pa
Morels are not a solid body lifter, if running a stock block smallblock you need to tube the lifter galley or bush the bores.
[Re: bones427]
#1665212
09/04/14 11:25 PM
09/04/14 11:25 PM
MR_P_BODY
Is that 40# at idle hot... if it drops with rpm thats not the lifters... either the pump has problems or the filter might be chocking it... first thing to try is another filter ![](/ubbthreads/images/graemlins/wave.gif)
[Re: bones427]
#1665214
09/05/14 11:17 AM
09/05/14 11:17 AM
MR_P_BODY
I changed the pump and 3 diff filters. have a wix racing on it know. 2 dff gauges. checked all the oil galley plugs are there. I'm lost!
I dont know but I wouldnt run it like that... time to pull the engine and find the problem.. the lifters could be right at the edge of the oil galley and with more rpm could be exposing the galley ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1665215
09/05/14 12:05 PM
09/05/14 12:05 PM
Posts: 5 usa ohio
bones427
usa ohio
whats weird is it had 60+ lbs . then lost the pressure. I have the intake off now and the lifters band isn't coming out of the hole. it's 40 psi at idle then drops from there as rpm increases. will be zero at 4000rpm. no I haven't ran it much because of this. will be pulling it soon.
[Re: bones427]
#1665216
09/05/14 12:11 PM
09/05/14 12:11 PM
MR_P_BODY
whats weird is it had &0 lbs cold . then lost the pressure. I have the intake off now and the lifters band isn't coming out of the hole. it's 40 psi at idle then drops from there as rpm increases. will be zero at 4000rpm. no I haven't ran it much because of this. will be pulling it soon.
With it cold the oil pressure will be higher and as it warms up will drop due to the viscosity change.. it sorta sounds like the by pass is going open as soon as the rpm comes up.. but you said you changed the pump ![](/ubbthreads/images/graemlins/wave.gif)
[Re: pittsburghracer]
#1665218
09/05/14 12:27 PM
09/05/14 12:27 PM
MR_P_BODY
After the issues I and many other had with high volume pumps I will never use another one. my standard volume pump works perfect. and my high volume pump is going on the scrap pile.
What was your issue with the HV pump ![](/ubbthreads/images/graemlins/wave.gif)
#1665220
09/05/14 12:47 PM
09/05/14 12:47 PM
Posts: 5 usa ohio
bones427
usa ohio
ya John , but mine drops like we talked about, not going up in pressure.John you have the stuff to tube the block? if so I'm Gonna have to bring it to ya! MR_P_BODY it has the same issue hot or cold.
#1665221
09/05/14 01:05 PM
09/05/14 01:05 PM
MR_P_BODY
Pump was going up over 130 pounds during my 1/4 mile passes. Thank God i didn't have a Fram filter on it.
I have to run a HV pump on my 416.. it has enough built in leaks that the standard pump wasnt giving me enough pressure(not enough volume).. I have the edm rollers and PR oiling.. the edm hole is .026 in each lifter.. the block is bushed but I went with a .060 hole in each... just lots of leaks ![](/ubbthreads/images/graemlins/wave.gif)
