Re: Looking For a Good book On Gen 3
[Re: MR_P_BODY]
#1665180
08/30/14 01:45 PM
08/30/14 01:45 PM
Posts: 411 Portersville, Pa
1badx
Portersville, Pa
The 5.7 (non-VVT) blocks are a good choice. Just be sure to sonic test the bores. It took me 3 blocks to find one I felt was acceptable. There was obviously quite a bit core shift when these were made.
As far as boost limits on stock head bolts and gaskets - we've taken a completely stock 6.1 engine to 28psi with no sign of head lifting. This doesn't mean I'd build a purpose built engine with this configuration - just relaying the strength of the stock setup. Go with head studs and Cometics.
Modern Mopar Forum is a good place for full tilt Gen III Hemi info if you don't mind the drama.
Here's a link to a thread on pushing a stock 6.1 to the limits: http://modernmoparforum.com/topic/12184-...e-photos-added/
What I'm looking to build wont use much boost.. maybe 15-20 psi max.. it'll be a stand alone injected with either a single or twins with intercoolers.. just a street/strip ride that will only run 10.0 in a 2900# Rampage... I'll most likely get the engine in and running then mock up for the turbo/s and see what will fit... nothing fancy for power
You wont need boost to run 10.0 at that weight with a Gen III Hemi. We have a customer with a 3700 pound 4 door, 7L running 10.30 NA. There's several others out there doing the same or close and many daily drivers weighing 4200#'s running high 10's NA.
[Re: 1badx]
#1665181
08/30/14 02:46 PM
08/30/14 02:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Yeah I know but when I can get to a few tracks I want to turn it up to see hat it can run.. mainly the turbo will be for looks and some fun... plus I want to run on 87 octane for the street and some 93 at the track... it wont run much boost.. MOST of the time
[Re: MR_P_BODY]
#1665184
09/01/14 04:55 PM
09/01/14 04:55 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Yes it is. Its just an oil tunnel that merges the rear oil drainback at the rear of #8 to the drainback between #6 and #8. Even if you went through, it would just drainback at the breach instead of through the 6-8 drainback.
Mopar to the bone!!!
[Re: 72Swinger]
#1665185
09/01/14 04:58 PM
09/01/14 04:58 PM
MR_P_BODY
thanks
