Re: MOPAR UNVEILS 2015 DRAG PAK CHALLENGER [Re: 68shifter] #1664973
08/29/14 02:34 PM
08/29/14 02:34 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I wish Chrysler would submit all the specs for the production Challengers. It took them several years to get the 5.7L and 6.1L engines in the Classification Guide for the non-DP Challengers. I think they could put the V6s in there in case someone wants to run lower classes.
As for the Hellcat, SS/AAA has a weight break of 5.0 pounds per HP. That would make the car weigh 3535 pounds. I bet that the production Hellcat Challenger can get down to that weight. I'm not sure there is value in putting that engine in the DP.
Re: MOPAR UNVEILS 2015 DRAG PAK CHALLENGER [Re: 68shifter] #1664974
08/29/14 02:37 PM
08/29/14 02:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
According to HRM it is getting the HellCat.. based
on info last night
Re: MOPAR UNVEILS 2015 DRAG PAK CHALLENGER [Re: sixpackgut] #1664975
08/29/14 02:37 PM
08/29/14 02:37 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
This. Even has "drag pak" headers on it.
Oh My God! Drool!!!!!! where can you get this? I had to fix the pic because it was hurting my neck
what gears come in those cars?
That's what I'm talking about!
2011 Drag Pak Challenger
Re: MOPAR UNVEILS 2015 DRAG PAK CHALLENGER [Re: mr_340] #1664976
08/29/14 02:48 PM
08/29/14 02:48 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I guess that depends if you like Ford and Chevy making faster cars than us.
Re: MOPAR UNVEILS 2015 DRAG PAK CHALLENGER [Re: rickseeman] #1664977
08/29/14 03:29 PM
08/29/14 03:29 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Rick, I've seen your posts on Classracer and seem to remember you are a long time Stock or SS racer, so I will go with your opinion. There was a Ford Cobra in the Classification Guides for years at 4.XX pounds per HP. Until they added the new weight breaks, it never had a place to race. If they put a Hellcat in a DP, where does it fit. They still have to get down to the minimum weight for SS/AAA. Is there an advantage of the DP over the non-DP Challengers with the same weight and engine combo? I think both can run the same rear axle and suspension. Maybe the non-DP has to run the 6-speed manual or 8-speed automatic. I did see where one of the Moosetangs ran a 7.9x run at Indy. I can't remember if that was Stock or SS. Got to be quicker than that then.
Re: MOPAR UNVEILS 2015 DRAG PAK CHALLENGER [Re: mr_340] #1664978
08/29/14 03:33 PM
08/29/14 03:33 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
68Shifter, where did you see that engine? Where can i get the valve covers? What supercharger is that?
Re: MOPAR UNVEILS 2015 DRAG PAK CHALLENGER [Re: sixpackgut] #1664979
08/29/14 03:48 PM
08/29/14 03:48 PM
MI
68shifter Offline
68shifter  Offline
MI
It's sitting at the Mopar booth here at Indy. Right behind the DP car. I saw it yesterday but they wouldn't take the cover off.
Whipple charger and who knows on the covers. It has several one off pieces on it. The guys around it don't know much. Probably a good job on mopar to stir the pot.
Re: MOPAR UNVEILS 2015 DRAG PAK CHALLENGER [Re: 68shifter] #1664980
08/29/14 03:53 PM
08/29/14 03:53 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
If you can sneak it out, i will give you good money for it
Re: MOPAR UNVEILS 2015 DRAG PAK CHALLENGER [Re: sixpackgut] #1664981
08/29/14 03:56 PM
08/29/14 03:56 PM
MI
68shifter Offline
68shifter  Offline
MI
Haha. Wish I could.
BTW P.B. Candies just went 7.85 for the fastest ever SS run. In muggy, hot, wet air.
Re: MOPAR UNVEILS 2015 DRAG PAK CHALLENGER [Re: 68shifter] #1664982
08/29/14 04:11 PM
08/29/14 04:11 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Re: MOPAR UNVEILS 2015 DRAG PAK CHALLENGER [Re: 72Swinger] #1664983
08/29/14 10:27 PM
08/29/14 10:27 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Barton already is .4 quicker than his nearest COPO Camaro. We already have the N/A bragging rights, its just a matter of time for the supercharged.
Hmmmmm
Car#-Driver(Opp'nt)-RT-----ET---Speed-----Car#-Driver(Opp'nt)-RT----ET---Speed
1990 David Barton 335X Dave Connolly
C3 0.077 8.940 149.22 ****WINNER**** 0.006 8.987 143.23
Re: MOPAR UNVEILS 2015 DRAG PAK CHALLENGER [Re: sixpackgut] #1664984
08/29/14 10:40 PM
08/29/14 10:40 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
what gears come in those cars? [/quote
And I thought gen 3 were ugly. Guess I was wrong.
Doug
Re: MOPAR UNVEILS 2015 DRAG PAK CHALLENGER [Re: dvw] #1664985
08/29/14 11:05 PM
08/29/14 11:05 PM
Winterpeg, Canada
hvyweight Offline
hvyweight  Offline
Winterpeg, Canada
Hopefully this will get Mopar on board to build a serious block that can handle big power for my 25.3 2010 Challenger! Then my last piece of the puzzle could be committed to.
Re: MOPAR UNVEILS 2015 DRAG PAK CHALLENGER [Re: cudadoug] #1664986
08/30/14 12:16 AM
08/30/14 12:16 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Hmmmmm
Ok so they are catching up? Last spring he went 8.76. Also wouldnt be suprised if the Bowtie babies caught a break from NHRA.
Mopar to the bone!!!
Re: MOPAR UNVEILS 2015 DRAG PAK CHALLENGER [Re: 72Swinger] #1664987
08/30/14 03:20 AM
08/30/14 03:20 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I wouldn't kick it out of bed for leaving tire marks.......
Re: MOPAR UNVEILS 2015 DRAG PAK CHALLENGER [Re: 72Swinger] #1664988
08/31/14 02:41 PM
08/31/14 02:41 PM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
Hmmmmm
They did! Before Indy they were allowed to run a bigger throttle body, larger valves and a bigger cam. Of course that is nothing new for NHRA. Just like it was in the past and is also now in pro-stock bike (HD's getting more displacement, etc than the Suzuki's).
In any event, I wasn't disappointed to see Connolly get beat in the final of FS/B on Saturday at Chevrolet's sponsored event!!!!
This post is available in double vision where drunk.
Re: MOPAR UNVEILS 2015 DRAG PAK CHALLENGER [Re: bwdst6] #1664989
08/31/14 08:36 PM
08/31/14 08:36 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Well there ya have it.
Re: MOPAR UNVEILS 2015 DRAG PAK CHALLENGER [Re: 72Swinger] #1664990
08/31/14 11:57 PM
08/31/14 11:57 PM
SC304 Offline
SC304  Offline
When this car and motor combo were unveiled Thursday night at Indy they stated they would build 50 2015 models. Some will be NA and some blown.
I asked if the Blown parts were going to be available for those of us who wanted to build cars and motors and the comment was yes.
The valve covers are billet pcs which are not quite available yet.
The Hellcat motor will be built at 354 cubic inches. It has to stay in line with the Ford and Chevys. The HP factor has not been agreed upon between NHRA and Chrysler. Nor has the shipping weight.
They plan on buildingn them this fall.
Lastly the Hellcat in its racing version will vary from the production / street version.
That's all for now
