Re: dominator lean tip-in
[Re: MR_P_BODY]
#1664796
09/01/14 12:37 PM
09/01/14 12:37 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
My thinking is the carb is to big. Air stalling on tip in. No signal to the boosters. Converter to tight. I run a super sucker under my dom on the hemi because my converter is to tight and i have 355 gears. It really helped street manners for a small engine and bad combo
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Thumperdart]
#1664801
09/01/14 02:43 PM
09/01/14 02:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Not saying they aren`t good just maybe a bit behind the times..............kinda like some guys on here............
Dom.. I know your snide remark was directed to me.. but I have had and used a A/F meter years before you bought yours last year.. but now that you have a new play toy your the PRO... thats fine by me
[Re: MR_P_BODY]
#1664802
09/01/14 02:51 PM
09/01/14 02:51 PM
Posts: 11,726 Portage,michigan
B3422W5
Portage,michigan
To the OP.... Had great luck with the pro systems 1100 dominator on my old stroker.... At the track.... It wasn't well suited at all to the street, loaded up... But I am not a carb tuner guru at all. That all said, the best all around street strip carb for that same motor was the race demon 1025 rs 4150 carb. Ran same as dominator at the track, and way better on the street. I was an idiot for selling that carb..... Super sweet piece
