Re: dominator lean tip-in [Re: MR_P_BODY] #1664795
09/01/14 12:35 PM
09/01/14 12:35 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I used a chassis dyno (war room,A&A) and had the idle set in a happy place, so they didn't need to touch that. yes, I agree. after dyno tuning always required larger main jets at the track, 2 sizes larger usually. that's why I decided it would be smarter to get an innovate wide band and tune it myself to real world setting. mainly I use it for wot jetting which I found on my combo is 12.8:1 range for best mph. I still tune idle by ear and then refer to gage to see if its in the ballpark and it is. none of that is an issue, its the tip-in. I can feel it surging and referring to the gage I can see its between 16-17:1 ratio, so the gage comfirms there's an issue.
Re: dominator lean tip-in [Re: MR_P_BODY] #1664796
09/01/14 12:37 PM
09/01/14 12:37 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
My thinking is the carb is to big. Air stalling on tip in. No signal to the boosters. Converter to tight. I run a super sucker under my dom on the hemi because my converter is to tight and i have 355 gears. It really helped street manners for a small engine and bad combo
Re: dominator lean tip-in [Re: sixpackgut] #1664797
09/01/14 12:42 PM
09/01/14 12:42 PM
Mt Morris Michigan
Mt Morris Michigan
you could be very well right. it is a 1080 he calls his 1100. I thought it was alittle large at the time, but he insisted its what my combo needed. I also wanted a 2 circuit build at the time and he once again insisted on a 3 circuit. he's the pro on these carbs so I just followed his lead.
Re: dominator lean tip-in [Re: mopar dave] #1664798
09/01/14 01:06 PM
09/01/14 01:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
PRO is a relative term................
Re: dominator lean tip-in [Re: Thumperdart] #1664799
09/01/14 01:43 PM
09/01/14 01:43 PM
Mt Morris Michigan
Mt Morris Michigan
at this point, you are correct. i'll give him a second chance and if it wont tune right i'm callin blp.
Re: dominator lean tip-in [Re: mopar dave] #1664800
09/01/14 02:22 PM
09/01/14 02:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not saying they aren`t good just maybe a bit behind the times..............kinda like some guys on here............
Re: dominator lean tip-in [Re: Thumperdart] #1664801
09/01/14 02:43 PM
09/01/14 02:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dom.. I know your snide remark was directed to me..
but I have had and used a A/F meter years before you
bought yours last year.. but now that you have a new
play toy your the PRO... thats fine by me
Re: dominator lean tip-in [Re: MR_P_BODY] #1664802
09/01/14 02:51 PM
09/01/14 02:51 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
To the OP....
Had great luck with the pro systems 1100 dominator on my old stroker.... At the track.... It wasn't well suited at all to the street, loaded up... But I am not a carb tuner guru at all.
That all said, the best all around street strip carb for that same motor was the race demon 1025 rs 4150 carb. Ran same as dominator at the track, and way better on the street.
I was an idiot for selling that carb..... Super sweet piece
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: dominator lean tip-in [Re: B3422W5] #1664803
09/01/14 03:49 PM
09/01/14 03:49 PM
Mt Morris Michigan
Mt Morris Michigan
I was looking for a used 1025 when I bought the dominator. couldn't find a used one for less than 750. sure do hold their value.
Re: dominator lean tip-in [Re: MR_P_BODY] #1664804
09/01/14 04:12 PM
09/01/14 04:12 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not saying you Mike and respect most of your opinions and it was not directed at any one person at all. I got my wide band 4 years ago and I`m definately no pro YET!
